Sqeeks & Creeks after new suspension
Old Jun 16, 2004 | 07:53 PM
1989TransAm's Avatar
Hey everyone, a few months ago I did a lot of work to my car regarding suspension, here's a list of things that I have done:
-Energy Suspension Control Arm Bushing Sets - Energy Suspension
Ball Joints - NAPA
Tie Rods-Inner - NAPA
Tie Rods-Outer - NAPA
Tie Rods-Sleeves - Coleman Racing
Idle Arm - NAPA
Sway Bar Bushings Front: 34mm - Top Down Solutions
Sway Bar Bushings Rear: 23mm - Top Down Solutions
Struts - KYB GR-2 Gas Strut
Shocks - KYB Gas-A-Just
Springs - Eibach Pro-Kit
Upper Strut Mounts - Spohn
Sub Frame Connector - Spohn Tubular
Strut Tower Brace - Edelbrock
Jam Nuts/Steel (Right) - Coleman Racing
Jam Nuts/Steel (Left) - Coleman Racing
Centerlink - MOOG
After everything was put it, all the noise that the car was making before, disappeared. I was amazed. However that is all gone now, as 6 thousand miles later, noises are back. However there are no more pops or clunks, more like sqeeks and creeks. Especially noticeable when going slow over speed bumps, making sharp left or right turns at slow speeds, and braking abruptly.
I feel it is something to do with the suspension, more so the springs or struts (the front). Is there some type of lubrication that needs to be done to correct this? I know everything was lubricated with polyurethane grease b/c of the poly bushings.
I was watching Trucks TV today, and noticed that on one of the trucks the guy had a special washer a big one, that went between the lower control arm and the spring, do our cars have that? Could that be what the problem is?
Old Jun 18, 2004 | 11:16 AM
anyone?
Old Jun 18, 2004 | 11:20 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Lube everything.
i would guess with all the poly suspension peices, it needs to be lubed.
Old Jun 18, 2004 | 11:21 AM
mykxt202's Avatar
Car: 82 z28
Engine: 400ci 450hp
yeah what he said.....Use a silicon spray it will last longer and won't dry out he rubber and plastic in suspension pieces
Old Jun 18, 2004 | 11:23 AM
91Z28-350's Avatar
Lube it again. I lube all my bushings and front end just about every oil change.
You're also probably noticing squeaks from your poly bushings in your a-arms. There's nothing you can do about that now.
Old Jun 18, 2004 | 11:36 AM
it's ok to use silicone spray? i thought u need special poly lube.
Old Jun 18, 2004 | 11:37 AM
Dewey316's Avatar
Car: 1990 Camaro RS
poly lube is silicone based.
Old Jun 18, 2004 | 11:44 AM
thanks...i dont get it thought, i thought these poly bushings were to help the situation, not make it worse. Should I go back to regular rubber bushings?
Old Jun 18, 2004 | 11:45 AM
Dewey316's Avatar
Car: 1990 Camaro RS
they will last a LONG time, if they aren't lubbed, they can make some noise. the noise isn't hurting anything. don't be scared to loob it up really good, a little extra won't hurt anything
Old Jun 18, 2004 | 11:49 AM
thanks again
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
