PBR rear disc
Old Jun 27, 2004 | 07:44 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
PBR rear disc
i have an 87 with a 9 bolt rear wit disc. im tryin to decide what to do for rear brakes.
will the pbr rear brakes bolt right on my rear or do i need any special stuff?
i did a quick search but didnt find the answer
Old Jun 27, 2004 | 08:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'll need to change the backing plates.
Old Jun 27, 2004 | 08:26 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following link concerns a 10-bolt. All but the backing plates is pretty much the same.
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Old Jun 28, 2004 | 09:21 AM
JamesC's Avatar
By the way, check the following link and you'll see the difference between the 9- and 10-bolt backing plate.
https://www.thirdgen.org/techbb2/sho...hreadid=241024
JamesC
Old Jun 28, 2004 | 09:39 AM
Car: Corvette
Engine: 5.7
so the backing plates from my 87 9 bolt wit rear disc wont work.
everything i see says 10 bolt and im tired so im confused
Old Jun 28, 2004 | 10:14 AM
JamesC's Avatar
I swapped the rear discs on my 10-bolt 85 IROC to the new style PBR's. To accomplish this, I had to use the newer 10-bolt backing plates (check out the first pic in the first link and you'll see what those looked like. Compare them to the pic in the second link). I assume, but have no personal experience, that you can do the same thing I did if you use the newer 9-bolt backing plate; these, however, may be difficult to locate. I suggest contacting Ed Miller on this board.
JamesC
hectre13
Dec 11, 2023 08:14 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
