disc brake question
Old Jul 6, 2004 | 06:40 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
disc brake question
hey i just swapped my stock one wheel peel drum brake rear for a posi borg warner with discs...i think my brakes are messed up... and it was sitting for a year i think... pretty rusty when i got it... how can i tell if the rear brakes are messed up? the car brakes fine.... but i think one of the calipers is loose?? i dont understand how this works... if i do need new calipers what do you guys recommend? and why is one caliper on the front of the rotor and and on the opposite side its in the back of the rotor??
Old Jul 7, 2004 | 08:21 PM
Spdfrk1990's Avatar
You have the pre 89 9 bolt anytime you buy a junk yard rear i say rebuild the brakes. Just buy new loaded calipers or save your self some money and switch to pbr's like i am. If not u will want to later.
Old Jul 7, 2004 | 09:10 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Raise the rear of the car, put it in gear, and see if the rear wheels stop when you press the brake pedal.
Swap over to PBR rear brakes like Frk mentioned. Those old style rear calipers are prone to not work right..
Just the way the General designed it.
Ed
Old Jul 7, 2004 | 10:36 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
PBR? what is that and how hard is the swap? how much cash also? is there any way to get the calipers both on the back of the rotor? also my e-brake only goes up like 3 clicks and it doesnt work at all is this related to the calipers being seized or broke? thanx alot for the help you guys rock
Old Jul 7, 2004 | 10:48 PM
Spdfrk1990's Avatar
Haha my ebrake does the same thing. Itll be fixed soon tho.
check this link. https://www.thirdgen.org/techbb2/sho...hreadid=246768
Old Jul 8, 2004 | 01:30 AM
ebmiller88's Avatar
Yep, those are what you want. Baer offers an upgrade to those for $800 but you can do it for $600 in a kit. If your e-brake doesn't work, odds are your calipers are seized up. If you have to replace anything, might as well upgrade to these while you're at it...and the PBRs put both calipers toward the rear.
Ed
Old Jul 8, 2004 | 07:36 AM
Spdfrk1990's Avatar
Mine doesnt work cause there isnt any adjustment in my ebrake and it is really tight. Well i dunno if that why it doesnt work but the calipers suck they were new remans.
Old Jul 8, 2004 | 04:57 PM
ebmiller88's Avatar
Did you try to free it up a bit by using the adjuster in the trans tunnel to loosen it up?
Ed
Old Jul 8, 2004 | 05:18 PM
Spdfrk1990's Avatar
There wasnt one on my car .Might be one under the console had it out b4 tho dont remember seein 1.
Old Jul 8, 2004 | 06:31 PM
ebmiller88's Avatar
Sorry, my mistake. You have a '90 and those don't have the adjuster down there, just the bar to hold the lines...can't adjust that.
Ed
Old Jul 8, 2004 | 06:33 PM
Spdfrk1990's Avatar
Yeh thats why i figured they dont work right im guessin the the pbr's they should.
Old Jul 8, 2004 | 06:48 PM
ebmiller88's Avatar
Ever heard of the free travel adjustment on the PBRs?
Read:
https://www.thirdgen.org/techbb2/sho...ght=adjustment
and
Ed
Old Jul 8, 2004 | 07:18 PM
Spdfrk1990's Avatar
Thanx if the ebrake on my pbrs dont work ill try that.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
