Cadillac brakes
Old Jul 7, 2004 | 01:13 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Cadillac brakes
Has anybody considered or used the Cadillac CTS-V Brembo brakes. They are 4-piston 14.0" X 1.25" front and 14.4" x 1.20" back. I think that they would work pretty well if they could be adapted to work. Since the CTS-V weighs 3900+lbs.
Old Jul 7, 2004 | 12:44 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I've seen those brakes and they are sweet, but I expect they would cost a lot, 1500$ +
Old Jul 7, 2004 | 01:24 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
whats the GM part number for them?
Old Jul 7, 2004 | 02:25 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
They are awesome brakes but you will need a very big rim, most likely 18’s.
Old Jul 7, 2004 | 02:56 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
I would be surprised if they were that cheap. From the dealer they probably would be 5 grand. 13" Brembros are over 2 grand, and just for the fronts.
Old Jul 7, 2004 | 06:38 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
I thought when i looked at the car they were 6 lugged wheels...
Old Jul 7, 2004 | 09:19 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
You are right it does have six lug wheels but the rotors can always be drilled for a 5 lug pattern.
Old Jul 8, 2004 | 02:47 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Had time to look up all the info and part numbers here is what I got.
The front rotors are 14 inch and the rear rotors are 14.4 inch. The front and rear calipers are 4 piston brembo calipers.
The front calipers are $95:
89047726 and 89047727
The rear calipers are $76:
89047742 and 89047743
I'll try to get the rotor part numbers too but you may not be able to drill them because the stock 6 lug pattern will be very close to the 5 lug pattern which will probably cause stress fractures. I am sure you could use the calipers with other rotors though.
Old Jul 8, 2004 | 03:19 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
front calipers are 114.17
you forget that they add a percentage into the final cost.
when posting from GMpartsdirect.com, just add it to the cart, and click the checkout link... that'll give you the true cost
otherwise, its the dealers price, and noone, including them, sells for what they buy it for.
Old Jul 8, 2004 | 05:06 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
That is unbeleivably cheap!! Does anyone have pics of what these brakes look like??
Old Feb 28, 2008 | 09:50 PM
B4CYA's Avatar
Car: 85 Z28/87 IROC-Z/92 B4C
Engine: Twin turbo LS9/SC LS9/L98
Transmission: RPM T56/T56 Magnum/700R4
Axle/Gears: 9"/Dana 44/10 bolt
Re: Cadillac brakes
The brakes look bad ***. Heres a pic.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
