Rear doesn't follow front!!
Car: Trans Am
I was driving down the highway today, and there was no one around, so I was just playing around. I sterted swerving around from side to side in my lane, and I noticed that when I turned in, the rear would keep going straight for 1/3 to 1/2 of a second, and then come in line. It doesn't feel right, and I don't think it's normal. What could be causing this? They are all poly bushings, and the panhard bar seem fine, as I tried to push the car side to side and it wouldn't move.
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
It sounds like your saying your car is Dog Tracking?? If so it's 4 wheel alignment time!!! Or you have something really wrong underneath
Car: '91 TA vert
Engine: turboLSx
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
sounds to me like youve got something loose under there . you may want to get down there with a couple wrenches and tighten everything up
Engine: T.P.I L98.
Transmission: TH350
Originally posted by iansane
I may be asking a dumb question but how can you align a solid axle?
Engine: T.P.I L98.
Transmission: TH350
Yeah; how is that a 4 wheel alignment?
Do you do alingnments?? If no, drop it!!!! It's not. Our cars need a thrust angle alignment. And I don't think he is being a smartass. He is making a correction. Misinformation although well intended can be disastrous.
Regardless, a TAA is in order. The alignment machine will detect anything bent or broken in the front end, but not the rear. The alignment tech, if competent, should be able to tell if the rear has any problems pretty easily.
Car: Trans Am
Tell me more about this Thrust Angle Adjustment. I don't understand how it would help when it tracks straight normally, but hesitates when turning sharply.
The alignment itself probably will not help the situation. But it will determine if anything is bent or broken. If everything seems OK, you could have a problem with your suspension parts binding, mismatched sway bars, or even in your head... j/k
I see you have a lot of aftermarket parts. Everything greased and moving properly?
Car: Trans Am
yeah, i'm pretty sure everything is fine. I tightened up all of the bolts, the front left control arm bolt was loose, but it didn't change anything. I just greased up all of the bushings like 2 months ago.
1992 Trans Am
May 10, 2023 07:19 PM
