manual brakes
Old Jul 12, 2004 | 04:52 PM
stroken_camaro9's Avatar
Car: 92 camaro rs
Transmission: th350
manual brakes
does anyone make a kit or is it even possible to convert my stock(vacuum) brakes to manual brakes. 92 camaro w/a 383 motor. have the brake booster going to the back of the carb. wanting manual brakes.
thanks
Old Jul 13, 2004 | 02:43 AM
homerneedspeed's Avatar
Car: 86 trans am
Engine: tree fiddy
Transmission: weak ass t5
i was wanting to know the same thing and have seen no info on this,
Old Jul 13, 2004 | 07:49 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
YES>>> Well sort of... Ed Quay makes a manual brake kit....It bolts up to the stock holes BUT 2 problems that add a challenge to the install...
1) It uses 3/16 brake line with 37 degree double flare on it...*****Stock brake lines use 2 different size ISO metric bubble flare...ID tell you the size but then Id have to kill you.....
Anyway to overcome that I found Adaptorfittings that screw into the stock distribution block which convert DIFFERENT SIZE ISO metric bubble flare to Standard 3/16 37 degree double flare lines.... Basically I bought premade 3/16 37 degree Line and bent it up myself....Using the adaptors All screwed and sealed perfectly....Ill try to get a pic....
2) This problem is more serious IMHO.... The pushrod in my kit was WAAAAYYYYYYYYY too long.....I mean waaayyy too long.... I had to work out the geometry of the throw and then cut the pushrod....It has an adjustable heim that allows for movement BUT with the rod soooooo long it did not have near enough adjustment.... The danger IMHO is that is a hardened Critical piece.... I cut mine slowly with a watchmakers lathe to the proper size....Id be really leary about taking a Power tool or grinder to the brake pushrod.....
Ed claims its a bolt in kit.....Dont let him fool you.... It bolts to the firewall and stops there....While you dont need to be an automotive genious to install the kit you do need to be smarter than the average bear... Biggest hurdle is getting the right metric bubble flare to standard adaptor fittings...
BTW you MUST remove your brake pedal and have Ed quay Modify the brake pedal to use the kit as well.... He welds attachment tubes for the pushrod to your stock pedal....
My kit works GREAT....So Far Ive barely noticed a difference between mine and stock EXCEPT for all of the ROOM I now have on the drivers side engine bay...
www.edquay.com
Old Jul 24, 2004 | 02:33 PM
twistedwedge's Avatar
Car: 87 GTA
Engine: 355 Chevy
there is a cheaper alternative to the edquay setup. All I did was buy a new manual brake master cylinder for a 82 s-10. I took my brake rod and got the geometry right and shortened it, had to drill a different hole in my pedal, and bolted the pushrod to it. I think that i spent like 55 bucks on the master cylinder.
A good person to contact regarding this is Stephen 87 IROC. I think he has some good pics of the install on his website.
http://www.hardtail.com/pics/gallery.html
scroll down to the manual brake pics
Old Jul 25, 2004 | 09:46 PM
Car: 92 camaro rs
Transmission: th350
kit
where do you find a manual brake kit for the 82 s-10 u were talking about?
Old Jul 26, 2004 | 09:05 AM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
There is no "KIT" you buy the manual MC and make the rest yourself. Nop one makes a complete bolt on kit...
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
