1/4 Mile Shock Adjustment
Old Jul 12, 2004 | 11:20 PM
slow91camaro's Avatar
Car: '91 Camaro Z-28
Transmission: auto
I have KYB adjustable shocks and struts and was wondering how I should adjust them for the track? The struts have four adjustments and the shocks have eight. From my minimal understanding of suspension I'm leaning towards the softest setting in the rear and the stiffest in the front. Does this sound right?
Old Jul 12, 2004 | 11:23 PM
25THRSS's Avatar
How do the agx's adjust? **** or screw driver?
Old Jul 12, 2004 | 11:29 PM
Transmission: auto
The struts have a screw at the top and the shocks have a **** at the base of the shock.
Old Jul 13, 2004 | 07:50 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
actually you want the front softer for better wieght transfer to help with traction and disconnecting the sway bar up there helps a little too.
Old Jul 13, 2004 | 08:37 PM
Transmission: auto
So should I go as soft as possible up front and a little firmer in the rear?
Old Jul 13, 2004 | 08:46 PM
meridius's Avatar
that is a good starting place, youll really have to mess with it to get it just right since every car is a little different.
Old Jul 13, 2004 | 09:06 PM
Transmission: auto
Sounds good. Thanks.
Old Jul 15, 2004 | 02:03 AM
BaddAzzRS's Avatar
Car: 91 Camaro RS
Engine: SBC
The KYB AGX shocks and struts are single adjustable units and as such your only able to adjust the amount of rebound. By this I mean that your only able to vary the rate at which the shock or strut expands while the compression rate remains constant. Just something to kepp in mind when making your adjustments.
Old Jul 15, 2004 | 02:39 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Set the fronts on the lowest setting and leave it there. You want very little rebound damper so the front raises quickly.
The rears I would recommend setting at about 2 clicks of 8. Then raise it one click at a time after two passes at each setting- as long as your times increase, then keep going one click at a time- once time decreases, simple enough, back it down one click to the previous fastest time.
Old Jul 15, 2004 | 03:46 AM
Transmission: auto
Yeah, I noticed that by just compressing them by hand. Not quite what I hoped for, but you get what you pay for.
Makes sense. I'll hopefully get to try it out this weekend, assuming I didn't screw up the TransGo kit I just put in (haven't tested it yet).
Thanks again for the advice guys, I'll let you know what kind of 60' I can come up with.
Old Jul 20, 2004 | 10:51 PM
BaddAzzRS's Avatar
Car: 91 Camaro RS
Engine: SBC
Well its been 5 days...did ya get to the track?....Im kinda interested in how much of a difference they made when you adjusted them. I have the same shocks and struts but havent had my car out yet. Just wondering what to expect
Old Jul 21, 2004 | 02:48 PM
Transmission: auto
Yeah, I did make it out to the track but didn't really get to test and tune the suspension. I ran into some tranny problems (2-3 bind) which limited me to only 3 runs and took my attention away from the suspension. My best 60' was my first run with a 1.83. That is a tenth off my previous best, but I also just put in a new converter (vigilante) so I can't conclude anything about the shocks and struts yet. I also did this at higher elevation than my previous best, at a track that doesn't hook nearly as well, on an extremely hot (high 90's, if not 100+) day.
It will probably be at least a couple more trips to the track over the next month or two before I can give you a definitive answer on the benefits of the new shocks. From a seat of the pants perspective I could feel the front lift and back end squat and was told it looked good.
Good luck with your car and sorry I couldn't be more of a help.
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
LT1Formula
Nov 16, 2015 01:13 PM
