Lowering Spring Question
Old Jul 15, 2004 | 10:41 AM
STOLN's Avatar
Hi,
I have just installed lowering springs 1 inch from Suspension Techniques and AGX adjustable struts and shocks last night. After driving for 20 minutes I notice that the front is lower than the back. Is this normal as the springs need time to seat properly or do I have another issue. Please help as I did this myself with a friend who knows what he is doing.
Old Jul 15, 2004 | 10:57 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
How much lower???? Are you sure that the end of each coil sat in the proper spot in the rubber isolater???? typically you can throw the height off ~1/2" or so if you have the end in the wrong spot OR if the isolater is not seated properly....
Also how did it sit before??? and what were these springs "supposed to do" Usually different kits will kive you a different look... some kits give you a LEVEL look...others Raked which is what you have...
Old Jul 16, 2004 | 08:09 AM
STOLN's Avatar
The back is 1 inch higher than the front after the new springs are in, this is a measurement from the center of the hub to the top of the wheel well. I will check the seating of the spring. Could it just be that because there is no weight in the rear that it will take longer to settle?
Old Jul 16, 2004 | 10:18 AM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
Mine sat flat from the word go...The suspension will settle a little but I doubt 1"..
Old Jul 16, 2004 | 07:22 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
A 1" difference is too much. The car should be close to level. It sounds like the front springs may not be positioned correctly.
The pig tails on the bottoms of the springs should be positioned on the inside of the A-arms. You will see (2) drain holes in each A-arm and the end of the springs should completely cover the first hole and partially cover the second.
Old Jul 16, 2004 | 08:22 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
If the fronts aren't in right, it would tend to make the front sit higher than it should so I don't think that's the issue. I installed my Eibach springs with new front isolators and the old stock rear isolators and did get a bit of a raked stance but it's really not that bad at all. Here's a link to the stance I got after I played with the rear isloators after the install. It has since lowered a bit:
https://www.thirdgen.org/techbb2/sho...ghlight=stance
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
redmaroz
Aug 16, 2015 11:40 PM
