J65 brake question
Old Jul 23, 2004 | 03:59 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
J65 brake question
Yo guys, my 88 IROC has the J65 4 wheel disc setup. I'm looking at pads for this thing, and one listing I saw says it uses the SAME MKD-154 pads front and rear. Both!
Other listings call for a MKD-413 on the rear.
Which is correct?
Thanks.
Old Jul 23, 2004 | 04:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The rear pads are an MKD-154, with one of the tabs cut off. That's probably the MKD-413 pad.
Old Jul 23, 2004 | 05:25 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The MKD-413 pad is the "1LE" Performance package pad, used on disc rears from '89-up and on the '88 1LE cars...all 4 of them.
Ed
Old Jul 23, 2004 | 06:11 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks for the correction!
Old Jul 24, 2004 | 02:03 AM
Tremo's Avatar
OK, since I obviously don't have one of the four 1LE cars, then my rear pads can't be the MKD-413.
So I guess it's MKD-154s all the way around, correct?
Do you guys know if anyone makes a slotted rotor for this thing?
Old Jul 24, 2004 | 02:09 PM
ebmiller88's Avatar
PowerSlot and a few others. For quick matches, go to www.tirereck.com and follow the instructions.
Ed
Old Jul 25, 2004 | 06:11 PM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Be careful with choosing rotors, because some people will try and sell you the wrong part. I found a couple of places that would sell slotted EBC rotors for a J65 but when I was looking in the EBC catalog, they don't have a rotor for a J65. I'm inclined to beleive the manufacturer and not a distributer, so check the manufacturer's pages before buying from whoever.
Si.
Old Jul 27, 2004 | 06:39 PM
Tremo's Avatar
I have confirmed that the 1988 J65 cars use the MKD-154 pads front and rear.
Powerslot looks to be making slotted rotors for the J65,
Now what would be the exact Bendix part numbers for those TitaniuMetallic pads?
Also, any info on the adjustable proportioning valve?
Thanks.
Old Jul 28, 2004 | 04:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That's easy. Part # MKD-154.
I've been ordering that part number since 1994, before Bendix started the Titanium stuff. The titanium is just a coating to help the bedding process; Bendix brakes always worked amazing for me. I honestly didn't notice a difference when they moved to that Titanium coating thing.
Old Jul 28, 2004 | 07:37 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
:hail: Bendix
Old Jul 30, 2004 | 12:50 AM
Tremo's Avatar
How about that adjustable prop valve to get the rears working harder? where do you get that?
Old Jul 30, 2004 | 05:31 AM
ebmiller88's Avatar
"Search" --- "adjustable prop valve"
Summit Racing (www.summitracing.com) ;
Online catalog;
Brake systems;
Wilwood Brake proportioning valves
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
