widest rear tires?
Old Jul 24, 2004 | 08:20 PM
pont82fbird's Avatar
widest rear tires?
i want to know what are the widest rear tires u can fit with little to no modification.
Old Jul 24, 2004 | 10:58 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I had BFG 265/50/16's on the back with no mods, I did radius the fender wells to make sure they wouldn't get cut. They will rub a little during agressive cornering.
Old Jul 25, 2004 | 02:03 PM
ckjoshz28's Avatar
without modifing your wheel wells and not sticking out at all 295's would fit with the correct wheel backspacing, but you may have to roll the fender lip
Old Jul 25, 2004 | 04:03 PM
bad_turbo's Avatar
I've heard with 17 inch wheel, you can squeeze in the rear 315/35 's.
Old Jul 26, 2004 | 06:29 AM
ckjoshz28's Avatar
sorry bad_turbo but 315 series tires in order to get any where near inside the wheel well one would have to take a torch and hammer to the wheel well in addition to rolling the fender lip and pont82fbird wanted to know the widest tire that will fit with little to no modification. I still stay by 295's as being the widest tire you can fit with only rolling the lip which is a easy modification. to learn how to fit 315's use that good o'll search button, you'll find its not to hard to do and some ppl have found it very rewarding. I personally can't wait to have the funds for 17x11 zr1s out back wraped in 315's but I have chosen to build my motor first.
Old Jul 26, 2004 | 10:44 AM
bad_turbo's Avatar
sorry for the bad information. I had read it in a book that the tire would fit. I guess I was misinformed.
Old Jul 26, 2004 | 05:11 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
275/40/17 fit with no modifications.
eightsixseven
Dec 16, 2024 01:50 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Djmathis123
Aug 24, 2015 02:53 PM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
Dialed_In
Aug 20, 2015 01:45 PM
