geting the 1LE calipers out
Old Jul 29, 2004 | 05:02 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Ok, I want to make shure I got this right before starting.
I would need 2 c-clamps right? & the pistons need to be pressed at the same time. after that take the pin out & the calipers sould come out. Right?
Old Jul 29, 2004 | 05:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I've never bothered compressing the pistons first, just pull the pin out.
Old Jul 29, 2004 | 08:03 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Thats what I tried but the caliper is rock solid.
Any sugestions why this might be hapening, & can I use a screwdriver to pry it out without damaging the caliper & its components.
Old Jul 30, 2004 | 06:15 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... since you can't get to the pistons while the caliper is still mounted, just pull the caliper towards you to get the pistons into the caliper. This will also force brake fluid back into the master cyl, so make sure it's not full before you start. Once you've got a little slack in the piston to rotor contact, you can pull the pin to get the caliper off.
You can use a c clamp or some big adjustable pliers to compress the pistons when you're ready to put them back on.
Old Jul 30, 2004 | 08:37 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Remove the E clip from the retaining pin and pull or lightly tap the pin out. Once you get the retaining pin out, the caliper will rotate upwards and out. It shouldn't take a LOT of agitation to get them off...take care not to damage them, they're not cheap. Don't worry about the pistons, they won't have any effect on the caliper coming off.
The pads also have pressure springs on them to maintain pressure on the retaining pin. These springs could hold up the caliper from coming off, just take your time and don't rush...that's how stuff gets broken.
Ed
Old Jul 30, 2004 | 04:48 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
THEIR OUT!
It wasnt that hard. I gues I was being over-protective.
Didnt need to compress the pistons or nothing. Just a hard pull from the botom.
Old Jul 30, 2004 | 06:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Don't be surprised if you have to compress the pistons to get the caliper back on though.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
