Removing Brake Booster
Old Jul 31, 2004 | 01:50 AM
1986tpiiroc's Avatar
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
OK, I did a search but found nothing. How do you remove the brake booster??? Where are bolts located and how hard is this job??? Brake Booster went out last night and I need to get a new one. When I got in my car last night, I got up to a light and it stopped normal, but I heard a hissing noise every time I pushed the pedal. Suddenly brakes got harder to stop and hissing got louder, only when brake pedal was depressed.
Old Jul 31, 2004 | 02:08 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Take off the vacuum hose from the booster to the check valve. Take the master cylinder retaining nuts off and pull the m/c forward so it clears the mounting studs and move it to the side with the brake lines still attached. Support cylinder to avoid stress on hydraulic lines. Remove the nuts from the dash side of the firewall and disconnect the pushrod from the brake pedal. Remove booster.
Installation is the reverse of assembly.
Old Jul 31, 2004 | 09:10 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
On a side note, those booster nuts are a pain in the a** to get off. lol!
Old Jul 31, 2004 | 09:35 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Piece of cake.
4 nuts, sort of behind the brake booster; and of course, 2 nuts that hold the MC to it.... use a 15mm deep well socket and a wobble joint, and you'll have them off in about as much time as it took me to type that.
Old Jul 31, 2004 | 11:25 AM
Car: 1986 IROC-Z
Thanks everyone for your response. Job Complete, I now have power brakes again. And yes, the 2 nuts toward the pass side, specially the top one were a PITA. Other then that took about an Hour from start to finish. Thats including putting kick panel back in place.
Old Jul 31, 2004 | 11:26 AM
Car: 1986 IROC-Z
Oh yeah, I Dont know how you would be able to do this job without the wobble joint. Just glad I had one.
Old Jul 31, 2004 | 12:13 PM
Car: 89 RS
Yup, sucks without the wobble joint. I still don't know how I did it without one lol!
Old Aug 1, 2004 | 02:13 PM
Car: 1986 IROC-Z
What causes a brake booster to go bad??? I thought it was going to be a leaky master cyl, but there was no leakage where the MC meets the BB. Well no leaks at all I should say.
Old Nov 1, 2005 | 03:46 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
RB you seem to make this an easy job but did you have 3 pedals when youve messed with them??
ive been stuck on the two nuts towards the drivers side for days and cant get to them...a standard socket obviously isnt deep enough but a deepwell hits a bracket that runs from my pedal assembly to the firewall (clutch MC bolts to it on the firewall)
it looks like the only way to get to them (with a manual tranny) is to complewtly remove the pedal assembly....anyone have any input?
Old Nov 2, 2005 | 05:51 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
I did it on my T5 car and I did not have the wobble socket either. PITA but you do not need to remove the pedals. 13 mm socket to remove the 2 nuts that are holding the clutch mc (support brackets are attached to them under the dash) then remove the 4 15mm nuts for the brake booster. 2 of them are easy 1 required a box wrench and patients the last one I think I remove one of the switches to gain access. That nut did not go back on cause I have no patience and my car is now 2oz lighter.
Old Nov 2, 2005 | 11:36 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
got them. very easy once you pull the brace for the pedals thats closest to the drivers side.
Old Aug 10, 2009 | 07:46 PM
crazy_hotrodder's Avatar
Car: 92rs
Engine: 355
Axle/Gears: 4.10 7.5 with auburn posi
Re: Removing Brake Booster
This is an old post I know, but I used it as a reference and the next guy might too. on a manual t5 the left side nuts are very easy to reach if you move the rod brace that is in front of the nuts and also drop the steering wheel (2 13mm(deep socket) nuts) use 2 12" extensions on your 15mm deep socket and you can even use a impact. just so the next guy's life is easier.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
3rdgenparts
Aug 8, 2015 07:09 PM
