Rear End Links - Do I need the kit or just bushings?
Old Aug 1, 2004 | 07:09 PM
Trevor K's Avatar
My car is only summer driven, and I've had the rear sway bar off before and it came off with ease, so I'm not worried about anything being seized up.
Can I just buy the bushings below:
http://store.summitracing.com/partde...-9-8105G&N=120 4294925130 4294923758 302302
Energy Suspensions PN: 9.8105
My car has a totally stock suspension, so I assume I don't need the sleeves since it should be correct from the factory?
I have no problem paying the extra $5-10 if I need the sleeves/nuts, but if my stock ones will do just fine then I will use those....
Old Aug 1, 2004 | 07:39 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If your long bolt, washers and spacer are in good shape then just replace the bushings. Often the OEM ones are badly rusted due to lack of any plating for corrosion protection. Even on cars here in SoCal I find about 1 in 5 that are so badly rusted that I have to cut the end links off with a power reciprocating saw. Aftermarket kits and the ones I sell are plated to help prevent corrosion.
Lon
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
hectre13
Aug 26, 2015 08:17 AM
