panhard bar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
panhard bar
just kind acurious as to what the difference between the panhard bar and watts linkage would be?
in function, performance and such
Car: 2005 BMW 545i
Engine: 4.4L N62B44
just curious cause I know on the first gen rx7 it is a watts linkage
why didn't they use that design on the thrdgen?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
packaging is probably the main reason. along with cost.
The watts link is also much heavier than the PHB setup. and with the very long PHB we have, the lateral movement is very little. To pull the watts link off on our cars, they probably would have had to mount it diffrently, and that the bell mounted on a backet attached to the frame, and then the arms attached to the axle from there.
For everyone who is currious, here is what a whats link looks like.
The center portion rotates, so as the length of the arms change during axle movement, it will turn, , but the centerpoint remains the same, thus no lateral movement of the axle.
darwinprice
17
Oct 11, 2015 11:51 PM
