New Motor Mounts Ooooh..
Old Aug 8, 2004 | 04:55 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I never realized how bad my motor mounts were till I took them out.
I was doing springs, and since the bolts were right there I took out the mounts. You can see they are compressed and shifted, I can't believe that they used such a small piece of rubber! That is part of the reason it shifted.
The new Energy inserts fill in the area nicely and look like a big improvment!
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
new inserts!
Old Aug 8, 2004 | 09:56 PM
laiky's Avatar
the old ones look like parts store replacements, the factory ones fill the shells.
Old Aug 9, 2004 | 05:22 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Nah, my ones looked even worse that the pics you showed. The rubber was splitting apart!
I got prothane parts and they didn't actually fit the engine mount part that sits on the engine. The metal tabs were out by a good 1/8" on both sides. Just had to modify the engine side of the mount to get the engine to sit properly. Not sure if this was something to do with what exactly I bought, or my 1979 350ci engine.
Si.
Old Aug 9, 2004 | 08:03 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I am positive those are the factory originals, my dad had the car from new, before I got it.
Old Aug 9, 2004 | 11:51 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My OEM ones looked like that. I put in ES ones and I couldnt shut my hood with the superram, so I went back to stock ones. Now it clears.
Old Aug 9, 2004 | 04:25 PM
JPrevost's Avatar
Car: 91 Red Sled
My stock mounts didn't look that bad but they were letting the engine rock enough to rub the hood.
Stock loose mounts put the engine down about 1/2 inch but in conjunction with an ES tranny mount it can lower the front of the engine from stock.
I hated the engine rocking back and forth so when I did my engine swap I did poly mounts... HUGE difference. There is no more "noise" unless you consider that now the engine moves only a 1/4" of rock with blips of the throttle. I found it to be an awesome upgrade. All of my bushings on the car except for the front LCA bushings are poly. I've also got NOT noise...it's called grease .
I would have gone with a solid motor mount but I think it's best to leave the engine unstreased in the stock mount locations. If I were going to stress the motor it would be from a front plate, not the waterjacket!
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
