what number represent how wide
Old Aug 9, 2004 | 03:39 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
what numbers on the tire represent how wide the tire is? I have 245 50 R16. what number represent the wideness? if i go wider am i going up on one number and down on another or what? thank u
Old Aug 9, 2004 | 03:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
In that number:
245 = section width (not the same as tread width)
50 = ratio of height to section width
16 = wheel diamter
Go up on the section width while leaving the aspect ratio constant, everything gets bigger; go up or down on aspect ratio while leaving the section width constant, the tire gets taller or shorter respectively. If you want a wider tire that's about the same height (typical), raise the section width, but decrease the aspect ratio; 255/45 or 275/40 would be sizes with similar outer diameter.
Old Aug 9, 2004 | 04:24 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
thanks sir.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
