budget brake setup ??
Old Aug 16, 2004 | 06:22 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Not looking to do the 1le upgrade or spend a lot of dough. Looking for opinions on best aftermarket pads in terms of performance, life, and amount of dusting. Hawks, EBC?? Also slotted/drilled rotors?
Old Aug 17, 2004 | 01:32 AM
CrazyHawaiian's Avatar
Car: too many ...
Are you just going to replace the pads and stuff or do you want to replace some of the equipment? If you want to keep the stock equipment then probably want new pads, better lines, and a proportioning valve. If you want to do a budget equipment replacement maybe look into the new SSBC dual piston calipers and then re-use the stock rotors. Still consider the lines and proportioning valve. Or if you want to take it a step further you can look into the C4/LS1/C5 conversion. All of those will come out cheaper than a brand new 1LE kit. If you're looking for a budget rear upgrade (from drums or something), I think the LS1 rears win hands down.
Terrell351
Jun 13, 2021 01:13 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Eric-86sc
Apr 3, 2016 03:52 PM
gta90
Sep 15, 2015 04:00 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
