9bolt rear calipers
Old Aug 23, 2004 | 01:46 AM
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
9bolt rear calipers
Who has rebuild kits for the calipers for the 9bolt rear brake systems. thanks, Cocacolakid
Old Aug 23, 2004 | 01:50 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
9 bolt brakes are no different from the 10 bolts.
Old Aug 23, 2004 | 04:46 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
What the
U sure about that. I have a 9 bolt rear end with disc brakes and a 10 bolt with disc brakes and they aren't the same.
Old Aug 23, 2004 | 05:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No doubt one set has cast-iron calipers with 10.5 inch rotors and the other has PBR's with 11.7 inch rotors.
JamesC
Old Aug 23, 2004 | 09:03 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Apeiron is right, although not really clear: All the brake systems are "the same", but just used on different rears. IE, all rear disc brake systems are the same from '83-'88 regardless of rear (Iron Moraine calipers) and all PBR rear brakes are the same on 9 or 10 bolts from '89-92.
Coke: Auto Zone, other parts stores, and the dealer will have rebuild kits...just tell them what car you have. But if you have '88-older 9 bolt disc brakes, install the GM recall kit in them while you're at it, you'll be glad you did.
Ed
Old Aug 23, 2004 | 10:22 AM
lancerracer's Avatar
Car: 1988 T/A WS6
Engine: none right now
what is the GM recall kit? I just bought a Disk rear out of a 87 GTA, an I am redoing the brakes and I ahev never heard of a recall kit.
Old Aug 23, 2004 | 11:49 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
https://www.thirdgen.org/techbb2/sho...hreadid=247419
Old Aug 23, 2004 | 11:53 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you have 82-88 rear brakes, I wouldn't get a rebuild kit from anywhere but the dealer, just to be sure that you get the updated parts.
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
zayne0
Aug 24, 2015 07:22 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
