Setting up an Adjustable Torque?
Old Aug 23, 2004 | 04:37 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
I have a Spohn Adjustable Torque Arm. I am not too familiar with setting this up correctly, so instead of me just wingin this one, I am looking for some tips on how I set this up correctly for the most optimal performance... Thanks a lot guys.
Edit- Yeah I meant "Torque Arm" in the tittle, damn typo...
Old Aug 23, 2004 | 06:13 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
First off, let me help with installation. When your putting that thing on the differential with the housing still in the car, don't make the mistake I did (doh!) and try to put the torque arm on by starting from the front and trying to fit it on front to back. You need to take the torque arm mount and slide it on sideways. As far as pinion angle, I don't quite remember how I did it and im sure someone will chime in and give you a hand. You want a -1 pinion angle for some good performance -2 for the track. Any lower than -2 is a waste of time and will not help performance.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
perZ
Aug 15, 2015 01:17 PM
