rear sway bar
Car: 1984 camaro
Engine: ethiopian gerbil, those things can really run, when you put food infront of it.
Transmission: whatever makes it go
rear sway bar
the rubber bushings on my rear sway bar broke on one side and i was woundering if this could cause a big problem after awhile and how long does it take to really mess something up? ive been drivng like this for about a month now havent seen any problems yet i was even thinking about removing the sway bar completly. the car is a 1984 camaro L41
Car: 89 GTA (88 Firebird V6 to V8 conversion RIP)
Transmission: 5 spd
Why would you take the sway bar off? It only costs like $20 or so to replace the sway bar pins and bushings... I'm not sure what it will screw up or how long it would take to screw something up... but for something so cheap and easy to fix, why bother taking the chance?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What exactly broke, the bar, the endlink, the bushings?
You have done some engine performances mods, now its time to start on the suspension. Atleast replace the bushings and endlinks. Swaybars are a good way to increase spring force. They are like adding really stiff springs but without the bad ride quality.
Car: 1984 camaro
the rubber bushing and pin that held it in broke on the drivers side
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
very easy/cheap fix, any parts store should have what you need.
Do not take the bar off, just fix it next payday.
Car: 82 Z28
Transmission: TH350
So your endlinks broke, you can get them at any parts place. Just ask for an endlink kit with bolts and the bushings.
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Get HD polyurthene ones while you are at it, mine was only 75 cents more than standard.
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
