Spohn sway bar
Car: 1970 Formula
Engine: 400 .030 over
Transmission: M21
Spohn sway bar
I have a friend who wants to buy my spohn swaybar but he has a 4th gen rear w/ the 4th gen swaybar. the spohn is the 1 inch and i dont know what the stock one he has is. i see that they are interchangable but he thinks that it will not work as well as the 4th gen stock swaybar because the housing is two inches bigger on each side. Which one will work the best?
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
theyre exactly the same dimension wise except thickness, his is prolly only 21 or 22 mm. just need new bushings and its good to go
darwinprice
17
Oct 11, 2015 11:51 PM
