Weak Brakes...Confusing...
Old Sep 2, 2004 | 11:32 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Okay heres the situation...I have a 1984 Camaro Berlinetta with a 89 RS Drum Brake Rear end in it. Also with a 91 Camaro Booster and master cylinder. And the brakes wont really work for ****. No matter if I'm going fast or slow if I slam on the brakes the car will just coast to a stop. I already tried bleeding the brakes and checking the lines and everything is fine. But for some reason the brakes just wont work good. My 1991 Camaro was able to lock up the brakes with almost the same setup except for one difference. The Proportioning valve...in the 91 I had an adjustible wilwood. I had 100% going to the front and about 90% going to the rear.
Is the 84 Proportioning valve weaker then other models?
Considering that the front brakes always get 100% pressure even with the factory valve. THen atleast my front brakes would lock up. Though for some reason it doesnt do anything at all. The calipers from the front are also from my 91.
Side Note: Even with the factory 84 Booster and master it was weak.
Old Sep 3, 2004 | 01:09 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Re: Weak Brakes...Confusing...
I had the same problem with my stock proportioning valve a few years back. I have owned this car for about 12 years now and gradually felt even the front brakes weakening over the years even with new rotors and pads (definately had proper tolerances with new rotors). The fronts got to the point they they would not lock no matter how hard I stood on them. I finally pulled the factory valve out and installed a new 1LE prop valve- problem solved. with everything else staying the same. All four corners then locked fairly easily and very equally if stomped on after that- I had rear disc on though, not drums (car was originally drum)
Old Sep 4, 2004 | 07:40 PM
REVLIMIT's Avatar
Engine: Built L98
Okay I put in the Wilwood proportioning valve and everything is good now. I can now lock up the wheels and the car stops pretty damn quick now. I guess the factory one was bad...or just maybe for that model or something it was weaker.
Old Sep 5, 2004 | 09:37 PM
Spdfrk1990's Avatar
Hey revlimit what willwood valve did you get sounds like a good idea but idea hate to reflare all the lines.
Old Sep 6, 2004 | 03:55 AM
REVLIMIT's Avatar
Engine: Built L98
I have the rotory **** adjustible one...and sadly your going to have to re flare all your lines.
Falcon50
Aug 22, 2020 03:26 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
lanceflame44
Sep 25, 2015 12:28 PM
Racerx974
Sep 19, 2015 10:16 AM
cstrobel65
Sep 16, 2015 11:54 AM
