my brakes failed
Old Sep 9, 2004 | 09:56 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
my brakes failed
ok so im driving to a car show all happy i got new headers and a dump and my car is sounding a nd looking great, im on the george bush turnpike and im coming up to the toll booth and i hit the brakes to slow for the speed bricks, turtles... let off the brakes 'bump' 'bump'. go over the bumps, and now the brakes feel like there is a stick holding the pedal from going down, i cant push the pedal down hardly any, and the car wont stop, itll slow a weeny bit but it wont stop, so i limp home and check for loose lines under hood and see nothing out of the ordinary. the brake booster hose to the intake looks fine and all conected.
what could a jarring bump do to my car to make the brakes fail like this, misalign a pad or something?what the heck!
-doug
ill check this in the morning, along with the car at work, thanks for any sugestions.
Old Sep 9, 2004 | 10:46 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
PooPoo happens! Sounds like you've lost either vacuum to your brake booster, booster has gone bad or you've lost pressure to the rear brakes!
Old Sep 9, 2004 | 11:04 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
More than likely it is one of the first two things mentioned..
Old Sep 11, 2004 | 11:06 PM
Engine: 350ci
turns out, it was the booster
gay
it hissed when i tapped the pedal and the p brake did work, so i wasnt SOL to get it to work
i had the tech swap in a reman unit for 50$ and i bought the thing, it was like 150$
least t works now
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
dbrochard
Sep 19, 2015 08:13 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
