9 bolt brakes compatible with 10 bolt brakes?
im wondering if i have the calipers, mounting brackets, rotors, and everything from a 9 bolt rear if i can take off my 10 bolt drums and replace it all. if so, how straight forward is it? thanks
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
10 bolt disc axle flanges have a different pattern than 9 bolt disc axle flanges, so the backing plates are different. Neither of them will bolt to your drum rear without fabrication.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you can weld or know someone who can, it's pretty easy.
In my case, the hub of the axle (they have to be pulled to remove the drum backing plate anyways) had to be turned down slightly because the disc wouldn't fit over it.
Clamp the disc brake brackets in place, line them up and weld the bracket to the drum flange. Hook up the brake lines and bleed.
E-brake cables have to be changed out from drum to disc brake cables. That's about it.
Here's mine...
Here's mine...
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ambainb
Apr 25, 2016 09:21 PM
Eric-86sc
Apr 3, 2016 03:52 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
