front brake upgrade?
Old Sep 16, 2004 | 01:04 PM
zz4z28's Avatar
I just got my car runing this week and I converted to manual brakes.
my problem is the car stops fine under normal conditions but when I am going really fast it not that great, I want to convert to a BIG bfront brake setup, but I will not pay the price BAER wants, is there anybody out there that makes a kitlike that one for allot cheaper or do I have to make it myself?
I am putting the willwood rear disk kit on the rear!
thanks, Marc
Old Sep 16, 2004 | 07:21 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
manual brakes? no wonder it does not stop good what was the reason for manual brakes over power?
jeff
Old Sep 16, 2004 | 07:25 PM
zz4z28's Avatar
clearance for the headers!
Old Sep 16, 2004 | 08:29 PM
Kandied91z's Avatar
you need a new mechanic. change your k-member to tubular to solve that problem. you will want power brakes.
check with ed....use the search button here and you'll find your answer.
Old Sep 16, 2004 | 08:45 PM
zz4z28's Avatar
it has a tubular k.
the headers don't go down like a regular header would. they come up and forward for the turbos! the power brake lines were touching the primaries.
Old Sep 16, 2004 | 08:54 PM
zz4z28's Avatar
is there anybody out there that has prefabbed bracketry or do I get to build it all myself?
Old Sep 17, 2004 | 03:28 AM
Kandied91z's Avatar
even with turbos you should have room, reguardless someone will chime in and help you hopefully.
Old Sep 18, 2004 | 09:41 PM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
Nope, absolutely nothing you can do. Your car is unsafe for the road. You should give it to me. For free.
Old Sep 27, 2004 | 07:08 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Add one of these
http://www.hydroboost.com/
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
