Swapping disk brakes?
Old Sep 23, 2004 | 06:39 PM
DiabolicalZ's Avatar
Car: 83 Camaro Z28
Engine: Carbed 350
Hey all, i picked up a cheap 9 bolt for my 83 over summer, going to put her in next year, but I'm interested on finding out if the disk brakes from my 83 will swap right over. The calipers and rotors need to be rebuilt/resurfaced on the 9 bolt, but everything on the 10 bolt is perfectly fine and in working order. I don't imagine there's a difference but thought I'd look into it anyway.
Thankya.
Old Sep 27, 2004 | 11:04 AM
Parrydise7's Avatar
You've got the iron Delco Moraine's, right? Have you changed the rear pads on those recently?
Ten-bolts use a different backing plate. Did you get the backing plates with the 9-bolt?
I'm editing this because I just saw a post by a guy that has a 9-bolt with the iron Delco-Moraine calipers. With that in mind, check your backing plates.
I've got a 10-bolt now. In the near future, a 9-bolt is going in and I'm adding the PBR calipers. The PBR calps need a different backing plate.
Frozer!!!
Jan 19, 2024 04:55 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
