Shock install
Old Sep 23, 2004 | 09:49 PM
subliminal's Avatar
Shock install
I bought some rear shocks today. I got a pair of Monro Sensatrac shocks for the rear. Anyone got any experience with these shocks? If so how do is the ride, good hamdling, comfortable ride? This is my first shock install. Can someone tell me the locations of the bolts I will need to get to.
Old Sep 23, 2004 | 10:03 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
well on my camaro i had to remove the rear carpet at the back seat and remove two foam things that cover the top shock mounts, and at the axel is kinda self explained no need for details..
Jeff
Old Sep 23, 2004 | 11:27 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
As Jeff said you need to pull back your rear carpet a bit to expose the top shock mount. I go from inside the car and sit in the back seat. For 4th gens you can lean under the hatch and do it. Anywhoo, pull off the foam triangle thingys and you will see the bolts. You will need to use a pair of vice grips on the stock shock shaft to keep it from spinning while you take off the nut. Since you are not changing the springs you can just lift the rear of the car by the rear end pumpkin and pull the shocks out once you take off the lower and upper bolts.
Old Jun 30, 2009 | 05:19 PM
GtoRockz's Avatar
Car: 1987 Firebird
Transmission: R4
Axle/Gears: Stock
Re: Shock install
Got it, thanks guys!
NORTz89
May 20, 2020 03:51 PM
LT1Formula
Nov 16, 2015 01:13 PM
kevyb1973
Aug 24, 2015 04:11 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
