popping...
Old Sep 24, 2004 | 02:26 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
popping...
i rebuilt my front end about 4 months ago, and it pops like a b****, anyone know how to get rid of the pops... thanks
Old Sep 24, 2004 | 04:28 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
I can't really answer that question, but mine is the same way. Basically everything in my front end is new except the center link. I even had the (typical) frame crack by the steering box welded and installed a TDS Wonderbar. Maybe there's something else I'm missing, but what else could be causing this popping in our newly rebuilt front ends??
-Paul
Old Sep 24, 2004 | 07:34 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
its crazy, i went through and torqued down ever single bolt...still pops...???
Old Sep 26, 2004 | 02:03 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Mine has SFCs, GW steering brace and all new front end parts - still popped and cracked like a bastard - turns out that the 6 bolts holding the crossmember on to the car were all loose - one was about to fall out - tightened them to 120 and no more noise.
Old Sep 26, 2004 | 02:39 PM
quadgoat's Avatar
Car: 1992 Firebird
Yeah, good call on that, I've read that before on the boards, unfortunately that's not my problem. I had the whole front crossmember out of the car when I put the new engine in and I tightened all the bolts back down to spec and have re-checked them since then and they're all still tight. Good thought though, maybe that's your problem 92rsbowtie? It's definitely worth a look!
-Paul
Old Sep 27, 2004 | 09:58 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
well i hope thats the case, this poppins driving me insane, ill take a look tommorow.......
Old Sep 27, 2004 | 10:13 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
i checked, there all tight..............
Turbok9
Dec 7, 2014 05:17 PM
jasonjsmith1986
Aug 10, 2012 07:24 PM
bbq014
Feb 16, 2011 12:41 PM
sunset92
Oct 13, 2004 07:30 PM
