PBR brake pad ID
Car: check
Engine: check
Transmission: check
PBR brake pad ID
Have a set of PBR brake pads here that I am not sure of the type. They have printed on the pad material edge the following:
JB CP26 FE
I searched the web high & low and couldn't come up with anything for that number.
The pad surface itself has a semi-metallic look but not of copper. More of a fine shiney steel look. Would these pads possibly be the 'Metal Master' PBR pads? The pad manufacturer is PBR as that is stamped into the pad backing plate.
As further reference the pads are from a C4 with 12" brakes. Came with the full calipers I picked up for my brake upgrade on the '92.
RBob.
JB CP26 FE
RBob.
dbrochard
Sep 19, 2015 08:13 PM
