Camaro Bolt pattern 5x120mm?????
Old Sep 29, 2004 | 10:35 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
ive seen on ebay a couple sets of nice wheel but they say they fit many BMW's and camaros as well. but the listed bolt pattern is 5x120mm and i thought that was different from 5x4 3/4
and what size tire do you suggest for a 8.5" wide rim??? i would like to run at least 275-285
Old Sep 30, 2004 | 04:10 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Well given that 4.75" is exactly 120.7mm I think they are the same! make sure you get the right offset/backspacing.
Tyre manufacturers publish the recomended rim size for their tyres. I know the kumho data is easy to :
for example :
http://www.kumhousa.com/Products/Ptn...=1&PtnID=KU-21
In this case you need at least a 9"rim for these kumho asx tyres. Other manufacturers/models may do a 275 that fits a 8.5" rim. You will also find many folks don't bother listening to the manufacturers and get away with it. Your choice.
Si.
Old Sep 30, 2004 | 09:14 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
o ok i thought that .7mm would throw it off but great! does anyone know what spacer is needed for 4th gen rims. i have one now and think its maybe 1.25" and wondered if it would work for a set of fourth gen rims
Old Sep 30, 2004 | 12:19 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
2" adapters all around for 4th gen rims
Old Sep 30, 2004 | 02:33 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
cool thanks
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
