Will moving this mess up my alignment?
Old Oct 10, 2004 | 09:20 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
1 month ago I noticed the dust boot was cracked. I checked it today and it was gone. I will just pull this side of the tie rod end out and put a new dust boot on.
Question: will pulling this out and putting it back in mess up my alignment?
I dont think so but I just want to be sure.
Old Oct 10, 2004 | 09:36 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
if your just taking off the cotter pin and the nut you wont mess up the alignment. if your taking the tie rod end off the rack then you will mess up the alignment
Old Oct 11, 2004 | 01:24 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Replace the grease too while your at it, you hopefully didn't do much damage or comtaminate the grease that much, but you should fully push all the old stuff out with new stuff.
Old Oct 11, 2004 | 02:23 AM
CrazyHawaiian's Avatar
Car: too many ...
As long as the tie rod adjusters are not moved I dont think it will alter the alignment at all.
Old Oct 11, 2004 | 02:53 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Pretty spindle..
Old Oct 11, 2004 | 03:02 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
pop the pin and nut off, hammer a pickle fork in between to seperate, wipe off excess crap, install dust boot and insert back into spindle with nut and NEW cotterpin. Would move a thing on the alignment.
Old Oct 11, 2004 | 03:22 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
Its Done, I pumped it out with lots of grease. I almost drove in the rain today before I remembered to swap it. All I had on hand was a used boot from the old tie rod end, it cleaned up good and seemed ok. Seem to ride the same.
thanks
nova983
European Region
Nov 2, 2015 12:15 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
89 formula TPI
Sep 20, 2015 10:54 AM
Denricci22
Sep 18, 2015 09:02 AM
dimented24x7
Sep 17, 2015 06:58 AM
