loose feeling rear
Old Oct 22, 2004 | 01:50 PM
deadhead1882's Avatar
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
loose feeling rear
ok hears the deal, when driving through the mountains i gotta slow down alot like were talking 50 through a 60 mph turn.
Otherwise it feels like my back end will just break loose. Im thinking i need a new panhard bar, anyone else got any suggestions
*edit*
this is with the 91, on the 92 i cant take the same turns at 80mph plus
Old Oct 22, 2004 | 04:09 PM
ede's Avatar
ede
tires
Old Oct 22, 2004 | 07:10 PM
Car: 82 El Camino
Engine: built 355
there brand new 275 40 18 falkens, been on the car maybe 3 weeks
Old Oct 22, 2004 | 08:10 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
if i were you i would put your car on a lift or jackstands and have a look under your car. Check out the bushings and look for bent parts such as the pan hard bar and also take a look at the sway bar endlinks (seeing as that has alot to do with cornering). You want to do a intire visual inspection of the rear end before comming to a conclusion. while you have it up you can change the differential fluid and look at the gears. Dont forget to check the drive shaft for play and such.
Old Oct 22, 2004 | 10:01 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
We would need specific details as to what if anything has been changed, altered, aftermarket (Anything from stock configuration). Don't know form the little info you have given if its componant related or just settings.
With those low profile tires though, my assumption and question is- is it dribbling out from under you? (back wheels feel like a basketball as you glance over road imperfections in corners)
Frozer!!!
Jan 19, 2024 04:55 PM
I'llrocya
Feb 2, 2016 11:43 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
86White_T/A305
Aug 17, 2015 12:16 AM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
