Trick new technology
Old Oct 28, 2004 | 02:10 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Anyone happen to see the new brake floater brakects that Afco has designed for oval track cars? This is trick technology. It bascally allows the calper to ride on the axle housing decoupled with its own radius arm attached directly parallel to the chassis. What this does is it entirely takes away all braking force off of the suspesion and directs it toward the chassis- No more brake hop, or brake dive. The rdius arm can then be position adjusted up or down on the chassis mount angle to either help load the tire with more force, less force, or even no force on the rear wheels under braking.
Too bad it can't be applied to a 10-bolt street axle with welded -on bearing flanges. I am working on a way to possibly engineer something of this fashion to these cars. This in essence would allow us to run a very short torque arm with no consequences at all from brake wheel hop and can run softer rear springs accordingly to induce squat. It is the same basic principle as a decoupling TQarm.
http://www.secureperformanceorder.co...ProductID=1065
Old Oct 28, 2004 | 03:27 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
That is badass, there goes my decoupling torque arm fabrication plans. I'll have to check it out and see what would be the easiest and best to do. Thanks Dean for the info!!
timonator
Sep 30, 2015 12:52 PM
RS Reaper
Sep 27, 2015 07:04 PM
Justins86bird
Sep 27, 2015 09:43 AM
92projectcamaro
Sep 24, 2015 08:09 AM
project89
Sep 22, 2015 09:35 PM
