My before/after drop measurements for Eibach ProKit vs stock springs
Old Oct 30, 2004 | 07:41 PM
johnblacksox's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 305 V8 LG4
I just replaced my stock springs (1986) with new Eibach Prokits. I also installed KYB shocks and struts, and new strut mounts.
I have an '86 305 V8 SC.
Here are the measurements in inches (ground to top of wheel wells) before and after:
1986 stock springs (before):
Left Front: 27
Left Rear: 27 1/4
Right Rear:27
Right Frnt: 26 1/2
New Eibach ProKits (after):
Left Front: 26 3/4
Left Rear: 27 3/4
Right Rear:27 1/2
Right Frnt: 26 1/4
So overall, I had a 1/4 inch drop on the front, and actually had a 1/2 rise in the rear.
I've just driven a few miles, but it definitely feels a lot better. With the old setup, I could feel every pebble, now at least it's not as bone jarring.
Old Oct 30, 2004 | 07:54 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
hmm is the 1/2 diffrence right to left normal? it seems frn and rear are both 1/2 off should the be the same? did you get an alignment of your front end after the installl?
jeff
Old Oct 31, 2004 | 12:02 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I just installed the pro-kit to. It lowered my front end drastically. But for whatever reason even with my stock springs my front end sat very high. Stock springs and 3 year old KYB gr2 struts and it sat higher than I have ever seen a thirdgen. The prokit didn't lower my rear much but the car looks much better. Rear is ever so slightly higher...but my front used to be much higher than my rear.
I didn't get KYB stuff again. I haven't had good luck with them. So I just got the monroe synsa tracs from work. I got the springs from work for 210$ tax and all
Car handles so much better now. And it doesn't shake on the interstate like it used to. Thanks to the front end rebuild.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
86White_T/A305
Aug 17, 2015 12:16 AM
