Power to manual steering
Old Nov 2, 2004 | 06:19 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
Im doing a complete rebuild on my 89 rs building a badass street warrior.... is there anything i can replace the entire power steering system with to save wight and reduce drag on the engine from the pump?
Old Nov 2, 2004 | 06:21 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
S-10 manual boxes
$40 and you wont believe the weight you'll be taking off once you pull the old ps set-up
Old Nov 2, 2004 | 06:26 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
Originally posted by IHI
S-10 manual boxes
But what years are a bolt in? Im looking into this too.
Old Nov 2, 2004 | 06:34 PM
IHI's Avatar
IHI
Mine came off a 92, and bolted straight in. Would I be right in saying 2nd generation S-10's? not the newer 94 and above style, but the older 8?-93 models.
Old Nov 2, 2004 | 10:00 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
82-93 s10 is the preffered. 94+ did not offer manual steering, but the older s10 boxes still bolt up to the newer body trucks.
have fun.
you could always get a flaming river box, it only weighs 12#
Old Nov 3, 2004 | 10:13 AM
Car: 87 Formula
Engine: 350 tpi
ok sorry for being oblivios to the steering systems on our cars but there not a rack + pinion right? so u can jus replace it with the s10 box and hook it up to the linkage
Old Nov 3, 2004 | 10:37 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Does anybody know what the steering ratio and how many turns lock-lock the S-10 manual boxs are? Probably way higher then the performance boxes. I'd like to save weight swapping one, but i can't lose the performance ratio.
Old Nov 3, 2004 | 11:02 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
the s10 box bolts right in, just reuse the factory camaro pitman arm off your original box
most late model camaros run a 12:1 ratio (1.25 per side;2.5 lock to lock)
the s10 box is 16:1 ratio (3.75 lock to lock)
if you do ANY type of corner carving or autocross/roadrace, the manual box is not for you.
this is for weekend cruising and drg racing. when working the wheel around corners, its rips back way to fast to keep proper control of the car, where as power steering comes back to center position slow and controllled.
the s10 is a great box, and ive even had my iroc rims on the car with 245/50 and have no problems turning the car at all. turning a hard right into a parking spot is the only time it gives a hint of trouble.
good luck!
Old Nov 3, 2004 | 12:13 PM
Car: 87 Formula
Engine: 350 tpi
is therw anythign that a else that a s-10 box would fit into if so maybe we could find somethjign with a quicker ratio
Old Nov 3, 2004 | 01:23 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
good luck!
Thats what i was thinking, i just wanted to know from people that did the swap, thanks.
Old Nov 3, 2004 | 01:58 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Yeah, I was debating on doing the swap also. What about belt routing for the water pump and alternator? How would that work without the PS pump?
Just using a shorter belt would work right?
Old Nov 3, 2004 | 06:09 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
are you using a factory TPI 2 piece bracket setup? alt and powersteering on the drivers side? i rode mine around on a facotry bracket for a bit with the manual steering. i think it was a 935k6, but my buddy did the same thing on his 92 and had to use a 923k6... guess it depends on the year by an inch or two.
might try a vega box, but i think the ratio on it is slower than the s10 (slower=easier to steer, just more turns on the wheel)
quick ratio is the last thing you want with manual steering. take your powersteering belt off and thats how bad a quick ratio manual box would be.
good luck, ill be glad to help.
Old Nov 3, 2004 | 08:08 PM
Car: 87 Formula
Engine: 350 tpi
ease of driving might just have to be a sacrifice id make to have a lighter car and take the drive off the motor my dads chevell is manualy steerign and u can barely tell when driving but in parking sots and moving around slowly it take a little armstrong steering but thats ok with me
Old Nov 3, 2004 | 09:06 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
powersteering is .08 at the drag strip on a average basis ive heard of people picking up more. with the parastatic drag and the weight pulling off, its worth it. engine compartment is so much more clean too. and the best part.... one less fluid to leak.
Old Nov 3, 2004 | 10:05 PM
IHI's Avatar
IHI
2 years ago with the small motor, the only change I made was installing a electric water pump and switching to manual steering and I picked up .5
We were all surprised by that too
Old Nov 3, 2004 | 10:10 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
that is a large gain. it could have been the weather. an electric waterpump is worth a tenth, so a half a second is a big jump.
lucky you.. where is my luck?
Old Nov 3, 2004 | 10:30 PM
IHI's Avatar
IHI
Swap was done over the winter and the .5 was a constant through the entire yr....what was I thinking getting rid of that motor Man that thing made me some money
Old Nov 4, 2004 | 07:11 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Wanting to go faster does that to you!!!
Old Nov 6, 2004 | 01:36 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
so manual means no pump and a bi*** to turn the wheel correct?ive seen a company that sell a manual rack and pinion set up.wats a upgrade to loose some weight and still run the pump for smooth turning
Old Nov 6, 2004 | 02:16 PM
IHI's Avatar
IHI
It's harder to turn than a ps set-up, but not difficult. For the guys looking to get that extra bit of umph for a little bit of time and hardly any money it's agreat swap.
Again, if ones only concerned with autocross type cars it's a bad move. But for the average person it's a swap worth the effort.
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
sailtexas186548
Aug 24, 2015 10:11 PM
