tubular K member install with headers on the car????
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
set of hooker long tubes #2210. im just too dang lazy to drop the exhaust and spend money on new gaskets. the a arms are off the car, and it looks as if the a arm mounts on the k member itself is gonna keep it from falling out directly. if i loosen the bolts, can i wiggle it out around the headers? i know the tubular one will slide right up, as the mounting points are MUCH smaller than the factory, BULKY, casting.
if i had a plasma cutter, id chop it in half at the oil pain.
thanks in advance.
thanks in advance.
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I had to take my passenger side header off to change the k member
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
thanks. i guess i gotta do what i gotta do.
anyone that has any tips or tricks, post up. im set on not having to take them off.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Linson
Aug 21, 2015 02:12 PM
