Question about hatch pull down motor
Old Nov 8, 2004 | 04:02 PM
Spdfrk1990's Avatar
Ok my hatch pull down motor seems like its taken its last pull. I need some opinions should i just get another one from the junk yard for a quick fix or you think it would be wise to spend the 102 dollars from TDS . Also maybe just get a setup from the junk yard with no pull down?
Old Nov 8, 2004 | 04:12 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
what does it exactly do? does the motor pull down real slow?
Old Nov 8, 2004 | 04:13 PM
Spdfrk1990's Avatar
Yes its getting worse and worse last time it just barely latched just sounds real weak like somethin when the battery runs real low.
Old Nov 8, 2004 | 11:17 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
yeah, mine is doing the same thing.. i think i might hit a jy when it quits on me... just replace the whole motor assembly
Old Nov 9, 2004 | 05:52 AM
Spdfrk1990's Avatar
I think the reason mine went out is cause when i painted it 2 yrs ago i got new weather stripping so it takes alot more effort to close it.
Old Nov 9, 2004 | 08:51 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Check the rails the motor slides up and down on. Sometimes the plastic-or whatever it is cracks and causes the motor to work harder than it has to. Maybe someone knows what GM used to "lube" the rails from factory. It looks like soap to me!
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
