hear rattling from my wheels
Old Nov 14, 2004 | 02:38 PM
superdave1767's Avatar
just put new tires on yesterday and i can hear
all four tires rattling checked all studs and lugs
anybody had this problem before???? any help
would be great Thanks..
Old Nov 14, 2004 | 02:56 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
did you have your wheels balanced before mounting them? Most reputable tire shops make that a standard procedure.
Old Nov 14, 2004 | 04:49 PM
yes the tires were balanced
Old Nov 15, 2004 | 02:10 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
The only rattling type sound I have heard coming from a wheel area has been the brake pads? Does it rattle when you drive or just when you spin the wheel by hand?
Old Nov 15, 2004 | 04:05 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
What is your car? Also what type of wheels do you have?
Old Nov 15, 2004 | 04:37 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
With the 91-92 Z wheels the center cap tabs that hold the cap on can break when installing. and will cause the broken tab to spin around making a rattling sound. happend to me once.
Old Nov 15, 2004 | 04:44 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Similar to what I was thinking. My center caps on my iroc wheels used to be really loose. I siliconed them down because a couple had lost so many tabs that they would stay on.
Old Nov 15, 2004 | 04:48 PM
It was the brake pads and its a 89 Iroc Z
thanks for the info 406tpi it took the rattle away
there was no clips on it just had the brakes done
2 weeks ago and never heard the rattle until I put the
new tires on it.
Old Nov 15, 2004 | 05:09 PM
406TPI's Avatar
Car: 1985 IROC-Z
Cool, glad I was able to help. I love simple fixes:rockon:
morrow
Jan 13, 2024 12:29 PM
TBRays98
Sep 6, 2015 05:05 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
mrdevontay
Sep 2, 2015 08:04 PM
