Trying to plant the rearend better....
Old Nov 25, 2004 | 03:11 AM
82crossfireTA's Avatar
Car: 82 Trans Am T-top, Red
Engine: 305 Crossfire
Transmission: Metric 200
does anyone know of anything that will help me get a little better traction short of moving the engine and drive train back a foot or more? Would the after market torque are help any?, is there something else that would help?
Im running a 427 small block chevy, with a 700R4, 4.11 gears with a detroit locker.
~Nick~
Old Nov 25, 2004 | 03:21 AM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
um...suspension work...tires....moving the engine/trans back a foot seems a bit extreme....
Old Nov 25, 2004 | 05:50 AM
Night rider327's Avatar
Car: 1988 Camaro
I'm fighting traction probs myself, but moving engine back is the wrong idea. That's great for a tube chassis car thats still being build, but for a door slammer no way. Too much work cutting out the floor pan, firewall, adding a full cage, tube type engine crossmember, etc etc
You need to look for the real fix not a bandaid.
Weight transfer and placement
non flexing chassis and suspension
sticky tires
Remove as much nose weight as you can, add move more weight to the rear if you can.. (glass hood, battery in rear, alum engine parts, etc ect)
Bind free front A- arm bushings, no front sway bar, "drag" type front shocks, "drag" type rear shocks
Sub frame conn., poly lower controll arm bushings, aftermarket lower controll arms, lower controll arm brackets, stronger flex free aftermarket torque arm, poly TQ arm mount/bushing, set pinion angle right so it's at 0* when you launch (to do that it has to be -2-4* sitting still)
Tires, tires tires, and tires again. Just a point.. I went from BFG t/a street tires to yoko avid s/t street tires. Both the same size, and my 60' times went down .03 sec.
Later i'm gonna try some nitto 555R drag radials. Those should drop my 60' atlest .2-.3 sec, being i'm still spinning the yokos for alittle over 60' and rolling into the throttle too
If you have to keep a "street tire" on it then look into the drag radials like the nitto, BFG, etc
If it's not a street car then look into like M/T streets, or hoosier quicktimes
If you don't race in a D.O.T tire class go all out and get a set of slicks
Old Nov 25, 2004 | 08:44 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Pretty much what nightrider said. IMO running that 427sbc with goobs of torque, combined with the 700r4's deep first gear and 4.11 cogs your in a extreme case of pushing any traction to the limits. That's an awuful lotta power to send to a granny first gear set-up and I bet your shift light comes on about as soon as youo react to the tree turning green.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
PurelyPMD
May 5, 2016 04:57 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
