can the front struts "freeze" in the extended position?
Old Nov 27, 2004 | 10:35 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
i've had my z torn apart for a few months now, with the struts either off the car or hangin' off the strut towers. today i put the tires back on and set the front end down on ramps but the struts apparently did not compress at all - they're still "stiff legged". i still have to take the back end down off jacks but when i do i was going to try to "bounce" the front end by jacking it and letting it down quickly to try to break them free or am i just wasting my time and need to replace them?
KAM
Old Nov 27, 2004 | 11:24 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
take it for a spin around the block and they should go down. i know when i jack up the front of my car and then let it back down the front end doesnt go down until i drive it a bit since the front end suspention is stiff.
Old Nov 28, 2004 | 12:10 PM
Car: '91 Z28
Axle/Gears: 323's
strange, but they settled back down when i put the rear end back on the ground...
KAM
Old Nov 28, 2004 | 12:49 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i think its also becuz the front springs are alot stiffer then then the rear spring are and then if u have good struts takes alittle riding to bring it back down.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
redmaroz
Apr 25, 2017 07:14 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
