Just did the ol' 4th-gen rear end swap...
Old Dec 5, 2004 | 04:29 PM
JungleMan's Avatar
Car: 91 Firebird, white
Engine: L03 :(
Axle/Gears: 4th gen, 3.23
Car specs in sig.
Haven't been able to drive the car yet though I still need to fix the assembly for one of the brake lines, finish up my front suspension work, and bleed the brakes...
Anyway, that's kind of off topic...as everyone who has done the 4th-gen rear end swap knows, the e-brake doesnt work, stock...so I want to get my e-brake fixed. Yes, I know I have an automatic, but I'm going to need it for inspection, and my mom who is not too well-versed on cars (but somehow found out that my e-brake does not work) is making me do it (though she is letting me drive the car, so long as I'm actively working on a solution for the e-brake)
I need to know what exactly I will need to get the brakes to work again?
The only problem I see, at a first glance, is that the cables are too short. I found some 56 3/4" cables at Napa for $20, those would probably work, but I've heard something about a bracket?
Please help, I'm confused. Thanks
Old Dec 5, 2004 | 04:56 PM
Marc 85Z28's Avatar
LT1 or LS1 style brakes? On my LT1 rear brakes I used Advanced Auto Parts cables listed for a 1991 Z28.
Old Dec 5, 2004 | 05:21 PM
JungleMan's Avatar
Engine: L03 :(
They're LT1 brakes.
So basically, what you're saying is, look for e-brake cables from a thirdgen with disc brakes (like a '91 Z28 would)?
Old Dec 5, 2004 | 10:18 PM
Frank_Blotto's Avatar
Car: 87 Camaro Z28
Engine: LG4, CCC
I did the 4th Gen rear swap as well and had a problem with my ebrake at first, but I got it to work pretty well, even though my cables were shorter and thicker. Maybe some rears have shorter cables than others? Anyways, what I did was zip tie the cables to the old brackets that "directed" the stock cables, so they don't flop into the driveshaft. I also had to move the piece that holds the ends of the cables farther down on the thing that connects it to the cable that goes to the ratchet/handle assembly. I hope that made sense, I don't know what that part is called. Hope this helps!
Old Dec 5, 2004 | 11:20 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yes, this should fix your problem.
Ed
Old Dec 6, 2004 | 12:27 AM
/\/3\/\/l8l3's Avatar
Fix it to an inline lock, front tires only........always a plus when your showing your *** doing sick burnouts.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
