bent axle
Old Dec 8, 2004 | 09:23 AM
IROCBlueZ28's Avatar
bent axle
Well, I just went through and ordeal from He!l with my rear end swap. I busted my pinion gear and found a matching posi unit at the local junk yard. I thought, easy direct swap...WRONG! First thing, the unit was not a posi! I could have ....and now....should have taken it back! But I like tearing into stuff, so I pulled the posi out of my old unit and put it into the one I just bought from the junk yard. Then I welded the axle tubes. Checked the lash, filled the unit with gear oil and installed it. AFter the install I heard my brakes rubbing, I though??????? After about an hour of messing with the parking brake, I noticed the drivers side axle was slightly bent and was bouncing up and down about 1/8-1/4 of an inch. Now that it's installed, I'm just going to hope the junk yard will cough up an 28 spline axle Just wanted to post this incase anyone else has such crapy luck in the future
Old Dec 8, 2004 | 10:45 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Yeah...I did three rear ends one day and out of the three, I ended up with three bent axles
So I know how you feel
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 7, 2015 09:41 AM
