Your opinions on seam welding a thirdgen?
Old Dec 9, 2004 | 08:45 AM
The Doc's Avatar
I was wondering what you guys felt about seam welding a thirdgen. Do you feel it would be worth it in terms of structural rigidity and stiffness?
If someone already had subframe connectors, but didn't wish to get a full roll cage would it be a worthwhile modification?
Old Dec 9, 2004 | 08:49 AM
The Doc's Avatar
On this below linked thread several people including RB83L69 suggest that it would make a noticeable improvement:-
Has anybody improved on the welds?
https://www.thirdgen.org/techbb2/sho...ight=seam+weld
Heres a link to a Japanese thirdgen page with some good pictures of seam welding:-
http://www.advanceauto.jp/project_3rdcamaro.htm
Old Dec 9, 2004 | 08:57 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
so you guys know what the hell hes saying, heres the link to the translated page:
translated jap camaro road racer page
Old Dec 9, 2004 | 10:01 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
After being under my car for numerous hours after doing my engine and trans swap this is something I also have thought about but was not sure of how well this would work. Man this would be so awesome to have done.
Kevin
Old Dec 9, 2004 | 05:31 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I am going to be hitting alot of the areas under the car this winter....if you really look at it, it's almost scarey..some of the spot welds and gaps that is. I don't plan on getting crazy with it, just going to hit the main spots.
Old Dec 9, 2004 | 06:32 PM
JPrevost's Avatar
Car: 91 Red Sled
I think I know where I want to visit if I ever go to japan! Those guys have one hell of a work ethic. That takes a LOT of time and a LOT of work but man does it look good.
The seam welding is a great idea. I'd definatly consider it if my car wasn't so rusty
Old Dec 9, 2004 | 08:02 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Thats about a $100,000 Camaro with all that fab work. Oh to have metal working machinery like that and time. I'm doing this in small potatos fashion right now to my Mini (same intense level, just not "looks" quallity in fab skills with metal.
The only thing I just don't get is why in the samuri did they keep those stock strut mounts after all that chassis stiffening. There talents could have mock up something solid for this in no time.
Old Dec 9, 2004 | 08:42 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Damn the japanese they can even make American cars better than we can.
I think i'm turning Japanese.
Old Dec 10, 2004 | 12:24 AM
bottledbird68's Avatar
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
We're planning it on the turbo car this winter, but we're also doing a 14 point cage at the same time...
Old Dec 10, 2004 | 08:50 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
matt you crazy ****.....what are you doing on this board?
lol
Old Dec 10, 2004 | 09:45 AM
OneBadZ4U's Avatar
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
That is a great link for that jap site.
On a welding note, I noticed that they welded the car up on jack stands. My car is just about as much apart as their's. I was thinking of welding the seams under the car while it was stripped. Is welding on jack stands with nothing in the car a horrible idea?? Any suggestions would be great. I truely don't want to put it back together spot weld it and then disassemble it to POR15 the bottom.
Old Dec 13, 2004 | 02:01 AM
lol
Hell, I figure I work on 'em often enough, and I own two so, what the hell....
Old Dec 13, 2004 | 02:04 AM
I wouldn't be too overly worried about it. I know a lot of people say it's a no no but if you've ever installed a set of subframe connectors with the car perfectly level and supported by the suspension, only to have to jack on the connector just to make it meet up with where it needs to go anyhow, you've questioned the whole thing regardless... If you're that far apart, I'd say go for it, as long as the car is supported and level, not crooked and sagging.
Old Dec 13, 2004 | 04:03 AM
Spdfrk1990's Avatar
I think adding the extra spot welds at the seams when you have a cage is a bit of overkill. I do think that welding the cage in extra spots like at the door pinchweld and the a pilars would help alot though. I am going to clean up the entire bottom side when it is on the jig and seal every sea. I am also in the process of scraping the inside right now and getting all the factory seam sealer crap out and after that im going to prime the floor boards with epoxy before i get the cage welded in. Im going slow right now though cause I dont get much time to work on it.
Old Dec 13, 2004 | 06:21 AM
CrazyHawaiian's Avatar
Car: too many ...
I think its worth it if weight really matters. Like if you went with a lighter cage and seam welds, versus no seam welds and a heavier cage. One thing I do know, if you ever crash a seam welded car the chassis is rubbish.
Old Dec 14, 2004 | 05:43 AM
The Doc's Avatar
Heres a link to a thread on the Fabrication board that's prety useful.
Lightweight chassis stiffening
https://www.thirdgen.org/techbb2/sho...hreadid=225361
Old Dec 14, 2004 | 07:51 AM
oil pan 4's Avatar
Car: 89 Firebird
Just do it.
Stitch weld it.
Old Jan 11, 2005 | 11:18 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Damn, them japanese boys put together a pretty brutal Camaro!! Now, they're probably just going to slide around in circles with it...
Old Jan 12, 2005 | 06:31 AM
Car: too many ...
No, that orange car is used for roadracing. Probably some series in Japan very similar to JGTC, which will soon become Super GT. Not everyone in Japan drifts, if thats what you meant by going around in circles. *shrug*
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
Amillionoh7
Aug 7, 2015 01:24 PM
