4 Point roll Cage
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
4 Point roll Cage
Does anyone know of a company that makes a 4 point cage? i dont want a 6 point cause it will be annoyin having to climb over a bar everyday but id liek the 4 point for general saftey since itsa t-top car you never know.
Car: '91 TA vert
Engine: turboLSx
I've got a comp eng. 8 pt roll bar. Not installed yet. Been sitting in the garage for the past year or so. If you don't like climbing get the swingout door kit.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sure buy an eight point cage and only weld in 4 points.
otherwise summit "might" sell one. i'd suggest picking up the phone and calling them. 800-230-3030.
otherwise summit "might" sell one. i'd suggest picking up the phone and calling them. 800-230-3030. Senior Member
Car: '86 TransAm WS6
Transmission: Custom TH700R4
AutoPower makes a 4-point, in bolt-in and weld-in. They are available with removable cross-bracing so you can still use the rear seats. Legal for SCCA, but not NHRA, if I recall.
Elephantismo
Feb 13, 2019 12:51 AM
