tranny mount= vibration
Old Dec 12, 2004 | 11:13 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Well like everything with my car, one problem fixed and twelve more appear. I replaced my corroded rubber transmission mount with a new polyurethane mount. Now the car vibrates to the point where my fillings are about to come out of my teeth. What causes this, anyone know?
Old Dec 12, 2004 | 11:48 AM
Chet's Avatar
Car: GTA
Sucks doesn't it I've been through the same thing, however mine doesn't vibe all that much, but nonetheless it's still there. What brand mount did you get?
This thread explains why you encounter vibes with a poly mount:
https://www.thirdgen.org/techbb2/sho...ighlight=mount
Old Dec 12, 2004 | 02:20 PM
Mister_Johnny99's Avatar
I put one in my 4th gen.
It was UNBEARABLE!
Pulled it out the following weekend.
Old Dec 12, 2004 | 02:24 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
I'm not sure what brand it is. I ordered it from Spohn. **** is driving my nuts. Mine vibrates like mad. I might replace it with an oem rubber and keep the poly for the track. Is there a spacer between the mount and the tranny? Guess I might have to take a look.
Old Dec 18, 2004 | 08:06 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I've had no problems with the poly trans mount in my Iroc, don't know what the problem might be.
Ed
Old Dec 18, 2004 | 09:57 AM
JPrevost's Avatar
Car: 91 Red Sled
It's real simple. I had the nasty vibration and then I noticed one of the bolts on the trans had fallen out. Next time around it was still pretty harsh so I removed that "pre-load" spacer plate and have been happy motoring ever since. Use lock tight and don't use the stupid spacer. I think the spacer is too thick and puts the transmission at a funny angle with the driveshaft.
Old Jan 13, 2005 | 01:50 PM
DeLorean247's Avatar
Car: 1982 Pontiac T/A
Engine: 350 Carb
Transmission: TH200c
I have a really bad vibration like you all are talking about. It seems like it may have started after I replaced my Trans mount.. The vibration you are all talking about is it in park also or only with a load on the trans?
-Michael
Oh and it is a rubber one from autozone
Old Jan 13, 2005 | 02:09 PM
Engine: 350 Carb
Oh and its a rubber one from Autozone.
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
