Subframe connectors ?'s going to have a set installed today
Old Dec 17, 2004 | 11:53 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I've got a set of Hotchkis and a set of Summit connectors.
One for each of my cars.
One is my 86 Trans Am with Heddman Longtubes, Spohn X-member and TQ arm, T56.
The other is my 88 Formula 305 TPI 5 speed with stock exhaust.
I am not sure which set to put in which car.
My trans am doesn't have the tranny, exhaust or anything installed yet so I can't test to see which will work/fit better.
I don't really care which set goes on which car, I just want to make sure that whatever goes on today, the other set will work on the trans am.
The summit ones are straight while the hotckis ones have one tube that has a bend in it, I think it's the driver side but I am not sure.
anyone have any experience with the summit ones?
I am getting them installed in 4 hours.
thanks
Old Dec 17, 2004 | 02:15 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
with the longtubes, neither one of the sets should interfere with the exhaust. i believe the summit connecters are the same as the jegs ones that i have and i have had stock exhaust, aftermarket exhaust in the stock location and now longtubes with a trud dual system and have never had any interferrence problems.
Old Dec 17, 2004 | 06:25 PM
Zepher's Avatar
Well, it looks like either one will work for iether car, but we didn't get to install the subframes on the 88 since the y-pipe is in the way.
I guess I'll do headers and a new y-pipe and try this again in January.
Old Dec 25, 2004 | 03:41 AM
tf0r1's Avatar
Car: 92 RS 25th Aniv. V8
Engine: 350 L05 TBI
Transmission: 700R4 Raptor
so how did you make out?
Old Dec 25, 2004 | 07:30 PM
Zepher's Avatar
going to get headers since modding the stock y-pipe isn't cost effective. Might as well put headers on since the manifolds will probably have to come off if one of th e studs break while removing the stock y-pipe. Studs are very rusty looking and are probably weak.
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
red90IROCls1
Aug 25, 2015 06:56 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mizz0313
Aug 12, 2015 06:45 AM
