relocation bracket install?
Old Dec 26, 2004 | 12:03 AM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Transmission: slipping 700r4, soon probuilt
ok i recently bought a 89 pbr rear. I was wondering if i can install the relocation brackets with out he rear installed in the car? Spohns instructions says to put jack stands on the frame and not on the rear itself. but i dont want to install them on the car and then take it back down to por 15 the entire rear. Also what exactly do i have to sand down to make the rb to fit the rear
Old Dec 26, 2004 | 09:33 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
lcrb goes on the same place the original lcb is so you can do it out of the car, the bracket does not go on the body. you can weld in the new parts and paint it all up then install everything on the car last.
jeff
evilstuie
Jan 9, 2020 08:29 PM
toronto formula
Nov 10, 2015 06:17 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
