Next on the list???
Old Dec 29, 2004 | 11:36 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Next on the list???
Heres my list of suspension mods so far...what next?
Subframe Connectors
-Alston Racing(not installed yet... considering an 8-point and ditching sfc's to gain some ground clearance)
Springs
-Eibach Pro-Kit
Shocks & Struts
-Tokico HP Blue
Panhard Rod
-Spohn Adj. Tubular
LCAs
-Pro-Fab Tubular
Poly Bushings (Grease by SuperLube)
-Prothane sway bar bushings
-Energy Suspension Hyper-Flex Kit
-Energy Suspension End links
-Energy Suspension Torque Arm Bushing
Steering Brace
-TDS Wonderbar
LCARB's
-BMR Fabrication
Strut Tower Brace
-Edelbrock TBI Brace
Tie Rod Sleeves
-Billet Aluminum
Old Dec 30, 2004 | 12:39 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Ground Control camber/caster inserts for your strut mounts. I am currently debating changing my HMS mounts for the GC units, or I may have a custom top clamp made to modify my HMS mounts better to eliminate stress fatigue.
Old Dec 30, 2004 | 01:48 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Have a link to where I can purchase these? Thanks man. Your car inspires me.
Old Dec 30, 2004 | 05:08 AM
Spdfrk1990's Avatar
Ill take some ideas also my car is in the teardown stage and need ideas for the new parts.
my list for suspension so far is
spohn lca's
spohn adj panhard bar
spohn relocation brackets
TDS wonderbar
10 point cage
bilsteins
1le brakes
hotchkis springs might goto sportlines or coil overs from spohn
Hotchkis SFC's
also want a idea on some type or strut mounts
havnt decided on a stb yet
I have sways off a 1le but might go with the CM spohn ones also.
spohn torque arm is somethin i still have to get
Ummm what else do i need?
Old Dec 30, 2004 | 06:00 AM
CrazyHawaiian's Avatar
Car: too many ...
I would say tires first, then maybe some aftermarket sway bars. How does the car feel? Is there anything that it does that you dont like?
Old Dec 30, 2004 | 07:23 AM
Spdfrk1990's Avatar
Sorry not to jack the thread but this will help you also. Im not sure cause my rear lca's and panhard bar have been sitting in my closet cause i didnt want to put them on till i had the rear out for my new rear brakes and put the relocation brackets on. As of right now the car is getting restored and the body put on a jig so it will be a lil while longer. As far as how it felt it seemed a lil loose but i figured the rear lca's and panhard rod would cure alot of that. I had hotchkis sfc's also forgot to add that i dont like them though so there getting cut off then the cage is going on. The cage will be on hopefully by the end of winter im just getting it ready right now and cleaning up the floor boards and I cut out the rear seat brackets cause i didnt want them just not much time with my schedule. Oh for tires i was going to go with the goodyear eagle gs-d3's
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Lbibb
May 5, 2016 12:00 AM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 4, 2015 07:48 PM
Dragonsys
Sep 25, 2015 03:51 PM
