Noise inside Spohn panard bar
Old Jan 7, 2005 | 11:55 PM
KnightWarrior's Avatar
Car: 1985 Camaro Z-28
Engine: 305 V-8 4BBL (H) Supercharged
Axle/Gears: 3.42 Eaton Posi
I just got my new tubular lower rear control arms and panard bar. They are nice beefy pieces with black powder coat and red poly bushings, but while unwrapping them I noticed something rolling around inside the panard bar. Might be some welding residual or something. Sounds small, like the tip of a pencil.
QUESTION IS will it make an annoying noise when I round corners. I doubt I'll be able to hear it all the way back there near the muffler and all. Anybody know?
Old Jan 8, 2005 | 02:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Probably a little welding zit rolling around in there. You won't hear it over the rest of the noises the car makes.
Old Jan 8, 2005 | 06:33 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Which panhard did you get? If it has an adjustable section, just undo it and shake it around.
If its the non-adjustable, err. I doubt you will hear it though.
Old Jan 8, 2005 | 08:18 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
You wouldn't even hear it if you drove a cadillac. Don't worry about it, probably just a BB from welding.
Old Jan 8, 2005 | 10:57 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Like what they said, either that or the metal shavings that didn't make out from when I cut the pipes. usually I tap them on the table to get the extra shavings out.
Nothing to worry about. You wont hear it
Kat
Old Jan 8, 2005 | 04:53 PM
You "usually tap them on the table," guess I got the one you didn't. Since it is a fixed one, I've UPS'd it back to Spohn. Hopefully they will send me one that was "tapped on the table."
My stock open-channel panard doesn't "Jingle" and for $100.00 I don't think my new aftermarket one should either.
Old Jan 8, 2005 | 06:21 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Dont blame ya.
Kat
Old Jan 9, 2005 | 08:33 AM
406TPI's Avatar
Car: 1985 IROC-Z
Old Jan 9, 2005 | 08:51 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
suck it up lol. you really think you're gonna hear that little noise? You think that little piece of metal is gonna change position when you're cornering and cause the *** end of the car to kick out? You should have just installed the part instead of being a candy ***, and wasting peoples time lol
Old Jan 9, 2005 | 08:56 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Justin...you hit the nail right on the head, or should I said you tapped right on the panhard rod
Old Jan 9, 2005 | 10:01 AM
Cooper's Avatar
Car: '89 GTA
Axle/Gears: 3.45
yo kat, I'll take the "jingly" one if you're just gonna chuck it
Old Jan 9, 2005 | 10:08 AM
69 Mustang's Avatar
Car: 87 Iroc Z-28
Engine: 355 Vortec Superram
Transmission: 700-R4
That's the new G-sensitive auto-adjusting panhard rod. You see the slug inside forces itself to the corner of the G-load to plant the tire in that corner.
I bet you take back your panties if the tag is crooked.
Old Jan 9, 2005 | 10:55 AM
Redbird's Avatar
Car: '87 Firebird
Engine: '89 Corvette L98, unstock
Axle/Gears: 3.23 posi
Man that's **** retentive for ya
I bet you complain when the umbrella is in your Pink Flamingo wrong.
Old Jan 9, 2005 | 11:09 AM
Prime's Avatar
Car: 91 Firebird Vert
Engine: LO3
LMAO You have got to be kidding me. Actually sent it back because you were concerned about the sound that something the size of a "pencil lead" would make while cornering? That would be one sound you would never hear, you have an f-body, they rattle and clack like crazy, you would not have heard that over the door and sub frame rattles. A little fyi for you, after installing polys you are going to hear a lot more rattles than before, because the polys will transfer more vibration to the car. And you were worried about the "BB".
Old Jan 9, 2005 | 11:20 AM
Can you feel the love in this room?
I'm more of a boxer-wearing type, I drink Jack Daniels straight, and no I don't return them if the tags are crooked.
Thanks for all the bashing, you people are great!
Old Jan 9, 2005 | 11:40 AM
Prime's Avatar
Engine: LO3
Thanks for providing the entertainment.
Old Jan 9, 2005 | 11:49 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
And you're an *******. (Yes, it takes one to know one, and I know I am one.)
You apparently do not know a damn thing about fabrication and I sure hope Steve, in this case anyway, does not replace it.
How the hell is it going to rattle around in there? Plan on doing a 360º rotational flip a few times? So it jiggles as you go around certain corners at speed, what the hell do you think it'll do? rip a hole in the side of the tubing?!?
Like everyone already said, it's most likely a welding zit. Probably happens a whole lot, and there may even be a few that dislodge after installation in a few instances.
Then again, if you want perfection, why not fabricate one your damn self?
Old Jan 9, 2005 | 12:03 PM
69 Mustang's Avatar
Car: 87 Iroc Z-28
And no I don't return them if the tags are crooked.
So you don't deny you wear panties?
The BB slug has the same effect as the flakes of Goldschlager that collect in the pit of your stomach over a lifetime since gold cannot be digested. Will you lose sleep over that now?
Old Jan 9, 2005 | 02:19 PM
EvilCartman's Avatar
Car: '82 Z28
What? Those gold flakes are collecting in my stomach? Damn, I liked telling people I was chitting gold
Old Jan 9, 2005 | 05:46 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
can't believe that you returned it.Your prolly one of those guys who shake it for 1/2 an hr to make sure you got every drop outta it.
Old Jan 9, 2005 | 06:43 PM
LOL HA HA HA HA HA
Old Jan 9, 2005 | 06:58 PM
05kcilS's Avatar
Car: 1991 Z28
Engine: 350 L98
you gotta be kidding me
Old Jan 9, 2005 | 07:10 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
it wouldn't have affected the performance of the part in any way.
shoulda kept it.
Old Jan 9, 2005 | 07:12 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
shoulda kept it.
Your avatar makes a great invention for this perfectionist we have here
Old Jan 9, 2005 | 08:02 PM
Soapbabe's Avatar
Car: 1992 Firebird
kitty, just have a new, specially tapped one set aside to send back to him
Old Jan 10, 2005 | 02:05 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Damn. You guys are harsh. I wouldn't have sent it back but would've been disappointed it make funky noises. If I pay that kind of cash for something I'd like it to be solid and not sound like a ford. Meh.
Old Jan 10, 2005 | 10:25 AM
philoldsmobile's Avatar
Car: 2009 Volvo V50 R Design
Engine: 2.0 turbo diesel
Transmission: 6 speed auto
Axle/Gears: yes, both
does Spohn have to replace it? its not defective in any way..
sheeeesh...........
Old Jan 10, 2005 | 02:45 PM
1BadThirdgen's Avatar
Car: Trans Am
If I was Spohn i wouldn't replace it..............
Old Jan 10, 2005 | 02:58 PM
/\/3\/\/l8l3's Avatar
For the price you pay for spohn I would def. return it for a full refund and get some paracing stuff.
I can't believe you guys don't agree w/ this guy
He can be picky all he wants because he paid a premium price for spohns stuff. Heck it would have to be plated with silver for me to pay those insane prices.
Old Jan 10, 2005 | 03:08 PM
12secformula's Avatar
Car: 94 Z-28
The only way I would have returned it is if it was serious noise that it was making.....something that may have been defective. I want to say that I just rcieved my Spohn Adj. T56 torque arm, and crossmember w/ driveshaft loop, and everything looks perfect. After I read this I even shook it for fear of this horrific rattling that KNightwarrior was talking about! Sheewww, nothing.....now I can sleep at night.
I am not trying to be rude but you give consumers a bad name when you send a part back that is not defective and has something as small as pencil shavings in it.
Old Jan 10, 2005 | 03:21 PM
Lets say you buya new turbo, and it has something inside it that shakes...would you want that turbo?
What about shocks? Want something in a shock?
What about a rearend? You want something inside a rearend?
There isn't anything that would make me want an item that has something large enough to make a sound, not only would I send it back, but if he refused I would file with the BBB
You pay for quaility not someone being lazy enough not to get everything out. Personally leaving stuff like that would lead me to believe they made this after a few coffee breaks and skipped a step or two which would make me want to send it back for a refund.
That is all
Old Jan 10, 2005 | 03:30 PM
Car: 94 Z-28
Turbos and shocks serve a different purpose. Those have things moving internally, so if there was something in it, then yes I would send it back. A panhard bar is a tube w/ ends on it. He said nothing a problem w/ the item that makes it defective. It would have served its purpose just fine. Obstructiion in a shock or turbo could affect the items performance, however a bb or metal shaving in a tube DOES NOT. I am sorry I just don't agree w/ you. If my $600+ torque arm had this minute sound that wasn't loud enough to be noticed when installed, I most certainly would not return, unless it adversely affected its performance. Man you guys should be greatful that Steve is out there making quality parts for our cars, if you have to return something for a good reason then its fine nut don't waste his time....... time he is using to make something I am waiting for.....A tubular K-member.
Old Jan 10, 2005 | 04:29 PM
Steve makes parts and I'm happy for him.
I"m not happy about shelling out the cash he wants for his items. NOT WORTH A DIME
They are nice, but nothing special to warrent the prices he charges.
I bet that is how he affords a nice site, advertising ect is with the insane profit margin on his suspension items.
I would never buy from spohn his stuff is priced like it is silver plated.
Here is something I want you to do, You own a car with hub caps? take them off and put in about 3 bbs in each wheel and drive it around....tell me if that isn't annoying..
Old Jan 10, 2005 | 04:42 PM
Car: 94 Z-28
Thats right dis one of the boards sponsers......your an idiot, he can charge as much as he does and most will perchase. His parts are of great quality and he is always working on something new for our cars. There are few manufacturers w/ a quality product like his. He has a business to make money, not give stuff away. You get what you pay for, and he makes a product worth paying high dollar for. Thats how the economy works.
OH, and a couple bb's in a hubcap would still be alot different than one in an enclosed tube, your right though it would be annoying and the only thing that could be more annoying would be to hear you and knightwarrior argue about how he was right for returning a part that was in no way defective.
Old Jan 10, 2005 | 05:02 PM
you dont pay a 'premium' for spohn products, you pay a quality price tag for a quality product.
in my work we produce the best karting brakes available. people still want them for 20 pence though.
the guy is being a jackass, pure and simple. i dont know why he is wasting the postage money, if you return a non defective part, you are surely gonna have to foot the postage costs.
were not talking about a crack or a rusty tube, were talking about a timy piece of swarf, or a tiny bead of weld spatter, a normal byproduct of a hand made part.
Old Jan 10, 2005 | 05:06 PM
"your an idiot"
"perchase"
I can spell
Old Jan 10, 2005 | 05:08 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Steve makes the best stuff for our cars. It isn't even really debatable anymore considering all the homework and reasearch he does. A little slag is normal for a product like this. I would bet that most of Steves cost goes to R&D as well as the HUGE liability costs that he must pay to send his stuff down the road. I am sure he is not rollin in the dough. If you made stuff for cars that drive all over the world, then you would understand. The liability is insane for anything that you develop and put on a car.
Old Jan 10, 2005 | 05:10 PM
Originally posted by philoldsmobile
you dont pay a 'premiem' froo spohn products, you pay a quality price tag for a quality product.
"the guy is being a jackass, pure and simple"
"froo"
"premiem"
"20 pence"
"timy"
www.dictionary.com wow, your amazingly not a jackass
Old Jan 10, 2005 | 05:11 PM
if i were steve, i'd cut the bar open, do something unmentionable inside it, weld it back together, and return it.
yes, as shifty quite rightly pointed out, a little slag inside the tube is perfectly normal. the part is NOT defective.
Old Jan 10, 2005 | 05:12 PM
/boggle
Old Jan 10, 2005 | 05:14 PM
"froo"
"premiem"
"20 pence"
"timy"
www.dictionary.com wow, amazingly i am a jackass
ummmm, anyone can change a quote and work in some errors...
it helps if the post isn't 2 replies above you...
Old Jan 10, 2005 | 05:16 PM
  #42
were not talking about a crack or a rusty tube, were talking about a tiny piece of swarf, or a tiny bead of weld spatter, a normal byproduct of a hand made part.
Old Jan 10, 2005 | 05:32 PM
  #43
Car: 94 Z-28
I can spell, i just type too fast, sorry! I just think your being unreasonable. I am happy you can spell, thats super. I believe in returning the defective not returning for dumb reasons, thats all. You are obviously very **** and picky about little stuff. I was just saying that IMO, he was wasting his time and Steve Spohn's time. I said what I had to say so I'm done but I'm sure you'll continue to drag this out. If you feel the need....go ahead. Oh, and I'm sure I spelled some stuff wrong....feel free to pick it apart for errors.:lala:
Old Jan 10, 2005 | 06:35 PM
  #44
Project's Avatar
Car: 85 Camaro Z28
not worth it
Old Jan 10, 2005 | 07:19 PM
  #45
Rage13's Avatar
Car: 89 Firebird
This was a post from Spohn on another thead. Explains his prices well (witch I think are reasonal prices for the parts he makes).
Originally posted by Project
It's not an R&D mark up, and the price will not come down, and probably won't go up for a long time either. As a businessman let me tell you, the cost of materials is a small portion of a product's cost. However, over the past 18 months the price of steel has doubled and I have not raised my prices on anything for three years. I just ate the increases.
When you are running a 100% legitimate business, the killer is the overhead. One word, insurance. Workman's compensation, health insurance, fire insurance, contents insurance, the list goes on, I have at least 10 insurance policies. I have to pay all of this for my employees. I want good workers who care about their work, and to get good workers you have to treat them good, I'm sure you expect the same when you're looking for a job. I'd be willing to bet that just my monthly health insurance premium is more then 99% of the members mortgage payment.
I also know that I am far from the highest price in this industry, and I know my quality is better then the higher priced stuff. I think our parts are very fairly priced. Believe me, I'm not getting rich, I'm just another blue collar worker who busts his *** every day just like the rest of you!
Thanks for the compliments, I appreciate them!
Steve
It's the old saying that you get what you pay for. If you want cheap parts, you get cheap parts. If you want good parts, they cost more, because they cost more to build. It's pretty much that simple. I list every single build specification of my parts because I'm proud of them.
Old Jan 10, 2005 | 07:22 PM
  #46
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Originally posted by Red Devil
You're an *******.
Old Jan 10, 2005 | 07:28 PM
  #47
Rage13's Avatar
Car: 89 Firebird
I'm waiting for that one too, will be buying it along with the lower a-arms, Adjustable Torque Arm, LS1 motor mounts and a full coil over set up. When the K-member comes out (wink wink, I'm winking really hard here Steve ) so I can put it all on at once.
Old Jan 10, 2005 | 07:32 PM
  #48
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Say hello to my little friend -->
Antips16
Oct 30, 2015 06:42 PM
Nick McCardle
Sep 10, 2015 08:36 PM
luvofjah
Sep 10, 2015 10:41 AM
87camaro87
Sep 9, 2015 10:29 PM
