Wierd Poping Sound
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Wierd Poping Sound
Ok, my car has allways hoped and skipped alitle when I turn it tight. Especially on pavement, sometimes it can even slide the tires. The thing is, I just put new shocks and struts on my car and now, most of the time. I get this popping sound that I can hear, and feel through the car. I mean, sometims it's pretty violent. The car needs an alignment, but will this fix my problem?
1992 Camaro
TH 700-R4
3.1 V6
150,000 miles
~Max
1992 Camaro
TH 700-R4
3.1 V6
150,000 miles
~Max
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Get the alignment and go from there it could be a bad ball joint or even a loose k memeber bolt or two ..
Car: 91RS, 91RS
Originally posted by cali92RS
Or bad upper strut mount bushing.
Yeah, I figured those were bad when I changed the struts. Couldent find anyone that sold them besides a dealer, and didnt have the money anyways, so I just changed the struts only. I guess the reason that would have never made noise before, is because the old struts were so shot that when I took the upper mount nuts off, the shafts just slid down inside the strut bodies.
But an allignment is a must do anyways, I'll update when that takes place.
Thanks,
Max
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Re: Wierd Poping Sound
Originally posted by myvmax1
Ok, my car has allways hoped and skipped a little when I turn it tight. ~Max
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
is it your front end? because mine did that too. itd slide the front tires kinda like u were saying too. my problem (along with bad allignment) was a bent ti rod end. check it out and besure thats not it. i came close to snapping mine. my car was in an accedent before i got it and the guys at the body shop skipped over it.
Car: 2000 Trans Am WS6 (Black)
mine "popped" through turns (like a u-turn, not a fast tight turn).... and it was the tie-rod ends...
